Kenova
04-23-2006, 05:25 PM
I'm thinking about changing my Vega over to a 5 stud bolt pattern with some bigger brakes. I would prefer to use the '67 - '69 F body or '68 to '74 X body spindles and brakes. The spindles are about the same height as the Vega's, and they have removable steering arms in case it should be necessary to alter them.
The upper joints are no big deal. that job can be easily handled by enlarging the big hole and drilling new ones for the mounting bolts. The lowers are a different story.
The options are:
-- cut down some F body ball joints to fit into the arm (if they can be cut that far). This would be a real pain if I ever had to replace them.
-- weld in an appropriately sized sleeve (if such a thing even exists) in place of the original Vega ball joint hole to accept the f body ball joint.
-- cut up an F body lower control arm and weld the ball joint hole to the Vega's arms.
I personally would prefer the second option, but I don't know if such a sleeve can be had. I guess it would be possible to have some made if I can find the proper dimensions.
Can anybody shed some light on this or offer some suggestions?
Ken
The options are:
Ken
