View Full Version : Fuel Line
Dwalk47
04-20-2006, 08:44 AM
I've been thinking about the fuel lines for my 67 camaro- I'm wondering if anyone just buys a stock fuel line and runs it right next to the old one for the bulk of the pressurized line?
Is it kosher to run the stock line pressurized at around 50 psi? What size is necessary for the pressurized line? Is the stock 3/8" fine or should I go with 1/2" since I'm ordering it anyway?
What size are the fittings on the pump that is supplied with the HSR?
Dan
Fuelie Fan
04-20-2006, 05:20 PM
3/8" is fine for most applications. Any hard line should be easily capable of carrying 50 psi. You'd probably want to replace your stock line, however, as a little crud can do a lot of damage to a fuel injector. At very least you will need to run a good post filter and service it.
Don't know about the fittings
