View Full Version : Mirrors under the hood, Howd they do that?
crazyfireman
04-19-2006, 01:00 PM
I have seen a couple nice ars with mirrors on the underside of their hoods and I cant figure out how they did it? I bought 2 large pieces of mirrored plexiglass and want to do it, but I dont want it to look crappy. Any ideas how?? The ones I have seen are inset in the indentions under the hood.
fladoans
04-19-2006, 01:39 PM
All the one's I've seen at shows were glued on with a silcone chalk. But, depending upon how much you want to spend you can buy a complete set fro Classic Industries now they are $170.00 for the mrirors and installation materials.
TonyL
04-19-2006, 01:44 PM
you could've used polished stainless too. It'd be more resistant to shock and heat damage and last longer.
use some pretty good caulk to secure it.
crazyfireman
04-19-2006, 02:03 PM
Thanks, I cant figure out how to get them in the slots?
TonyL
04-19-2006, 02:45 PM
im guessing that they are just cut to the exact same size as the hole.
use paper and a crayon to get a "rubbing" of the holes. (tape a paper over the hole, then rub with the crayon to get an image)
Then cut it out and use a jigsaw to cut your peices to fit, sand them down, and then use a torch to heat the plexi to get a clean, glass-like edge. plop some adhisive on the back and place it in there!
that should be all there is to it.
crazyfireman
04-19-2006, 03:42 PM
That is what I figured I wil try it out, Thanks! ( I will post pics when done unless it turns out like crap!
