View Full Version : what is largest engine i can put in a 1985 camaro
drawde2474
04-18-2006, 02:57 PM
what is the largest engine i can put in a 1985 chevy camaro and what trans would go with it
CRUSTY69
04-18-2006, 03:02 PM
big as you want...th400 trans will work
drawde2474
04-18-2006, 04:25 PM
you know were i can get a rebuildable 500
drawde2474
04-18-2006, 04:27 PM
what axle would i have to put on it and is there a certain drive shaft i should use
drawde2474
04-18-2006, 04:33 PM
or a 454
Lowend
04-19-2006, 12:24 PM
... How big of a hammer do you own?
Seriously the largest engine you can use without some serious fab work would need to be a small block variant.
The largest GM small block ever was a 400; that is were the term 406 comes from, as a 400 overbored .030 makes 406 cubic inches.
I have seen small blocks as big as 464, but realistically the biggest you can go on a budget (that will drop into an 85 Camaro) is 396
4.030 bore x 3.875 stroke
rocketman
04-19-2006, 02:09 PM
i would stick to a sbc,they are easy to fit if no mods,good choice of headers,i would use a 700r4,or 200r4.i would build a 434 with efi.
slowcamaro
04-19-2006, 02:22 PM
I agree a smallblock would be easier, and probably a better choice for this vehicle.
That being said Ive seen plenty of bigblocks in third gens. Lots of engine swap info over at thirdgen.org
