View Full Version : LT1 rear brake swap...
68RallySport
04-13-2006, 02:05 PM
Getting all the parts together for the brake swap. I learned that u need to right side caliper brakets to clear the 68 camaro staggered shock setup. My question is do i need two right side calipers??? Or do i use a left side caliper with a right side bracket???
David
68RallySport
04-13-2006, 02:06 PM
Nevermind i thought about it harder and well i dont think u could even use a left side caliper with a right side bracket! Guess taht means two rights!
night_rider_692004
04-13-2006, 03:41 PM
I'm preparing a similar swap with Corvette LT 1 brakes (big brake option)!
The brackets are the same for left and right.
What setup for the emergency brake for your swap you will use?
I skip the staggered shocks and will change the sides of the calibers because of the bledding screws. The calibers are between axle and trunk (At the Vette LT 1 tha are in front of the axle)
68RallySport
04-13-2006, 06:16 PM
I thought the brackets where different side to side? I already know im gonna need a custom ebrake cable and it looks like its gonna be hard to fabricate but we will see when the time comes. Ill make sure to take plenty of pictures!!!
MarkM66
04-14-2006, 06:20 AM
The brackets are in fact different from side to side. If you have staggared shocks, get to right side brackets and two right side calipers. Done it.
night_rider_692004
04-14-2006, 01:33 PM
I spoke about Corvette LT 1 brake caliber brackets and I think they are not different. But I will check this tomorrow.
68RallySport
04-14-2006, 08:44 PM
Any pictures???
torose
04-16-2006, 10:42 AM
This guy did his 68 which maybe similar to what you are doing, has pictures and detailed explanation
68RallySport
04-16-2006, 04:22 PM
Torose i dont see any info? Who, what and where? I have done a bit of reasearch looking at David Pozzi's page and links as well as Torkers site which all had really good info...
David
MarkM66
04-17-2006, 09:29 AM
Just get the two right side calipers and brackets and you're good to go. It's easier then taking the drums off, lol.
CarlC
04-17-2006, 03:22 PM
http://www.geocities.com/torkerscamaro/torker.html
