View Full Version : 2nd gen Camaro front suspension problem
qwik1320
10-12-2004, 07:51 PM
My 73 is FINALLY back on the road after a year+ and I'm working out the last of the bugs (I hope).
Need advice on this one: :help:
The car tracks straight, if I let go of the wheel on a flat road she stays the course. However, when I go over a dip (when the front suspension compresses) the car pulls to the right. The front suspension wasn't taken apart during the repair and I haven't had it realigned since the accident. Could being out of alignment cause this?
It pulls to the same side that I was hit on.
10-12-2004, 08:11 PM
I'd get the alignment checked, but first look at the steering linkage to see if it's bent or maybe a tie rod end is damaged inside making it loose. Look at the idler arm too. Most have plastic inserts inside that can get split if you hit something.
David
qwik1320
10-16-2004, 10:06 AM
Thanks David. I checked and everything is tight and nothing looks bent. I'll schedule a front end alignment.
