View Full Version : Chevy 8,5" 10 bolt strengthen with welding?
night_rider_692004
04-13-2006, 02:00 PM
Hello!
I'm overhauling a 8,5" Nova rear for my 69' Camaro.
After sandblasting I noticed an oil surface at the area where the axle tubes are pressed in the diff. case and at the welding spots of the diff case to fix the tubes.
I saw that, for example Moser, weld the tubes all around to the diff. body.
Is this possible without any delays of the axle tubes or anything else?
Chevy350
04-18-2006, 10:13 AM
http://www.pozziracing.com/rear_axle_.htm
Midnight68
04-19-2006, 08:49 AM
I have heard that unless you are running 11's it isnt really needed. here is some good info on how to
http://www.nastyz28.com/forum/showthread.php?t=18890&highlight=welding+axle+tubes
04-19-2006, 03:36 PM
I read an article about a rear end shop that Mig welded the tubes to the center section. Normally I'd think you'd use a nickel rod, but Ni rod is not that easy to use. I tried the Mig welder and it worked very well.
