View Full Version : What compressor with LS1 and Vintage Air
carone
04-11-2006, 09:14 PM
What compressor should I run in a 69 Camaro with and lS1 and vintage air?
Steve68
04-12-2006, 02:59 AM
Sanden 508, now you have to pick which goofy bracket you want to run
Bill Howell
04-12-2006, 07:40 AM
Street and Performance probably has a bracket that you can use.
68LSS1
04-12-2006, 07:02 PM
They do but it moves high on the passenger side. Kit around $600.00 last time I checked a couple years ago.
Steve68
04-12-2006, 07:25 PM
There's a newer one out now, not so much monies,
Patrick
04-14-2006, 03:55 PM
Is this an S&P piece?
Steve68
04-24-2006, 06:19 PM
Yes it is, smaller bolts to the head, and polished, bling bling, it should be on there page,
StuckInBaghdad
10-10-2006, 05:02 PM
Can you use the factory compressor that is used on the ls1?
Steve68
10-11-2006, 02:44 AM
No, the VA system and the GM system are variable pressure systems, It would work for alittle bit, and then the system would grenade itself, thats what I was told by a reputable VA installer,
Steilow built a bracket system for a Sanden, but I don't know what pully he used,
scogin918
10-11-2006, 05:42 AM
Vinatge air makes a bracket that puts it back in the stock location. It came with the kit ordered from Detroit Speed.
Steve68
10-11-2006, 10:58 AM
They must have finally come out with it, awhile ago the sent me a pic of a so called proto type, I wasn't really that impressed with it, but I'll check it out now,
VenturaII
10-11-2006, 03:27 PM
S&P sells one that mounts a Sanden in the original Fbody location,(lower right) but moves it forward to miss their motor mount plates. It deletes the original A/C belt and runs off the front belt.
Payton King
10-12-2006, 05:28 AM
It will work on a stock subframe but you will need to notch it a bit.
Steve68
10-12-2006, 02:23 PM
PK, come on man give us a closer pic PLEASE!
oh buy the way very nice!
Payton King
10-13-2006, 04:57 AM
If you go to www.hotrodlane.cc (http://www.hotrodlane.cc) they have an online cataloge. I think it is on page 60 but not sure. I am using the system that retains the stock GM bracket (fbody) for the power steering and pump.
Tell me what you would like to see and I will get you a shot
JayBird
10-13-2006, 05:20 AM
Looking real good Payton!
datsbad
10-13-2006, 06:30 PM
It will not work on a stock subframe!!!!!!
Steve68
10-14-2006, 05:05 AM
So, you still need to make a cut out, anybody see the on MarkS used on X he made his own, but I think you need to add another pully to the hub.
Ron S
10-15-2006, 04:25 AM
I just finished helping a freind with an ls1 conversion in a 66 Chevelle which we used the Vintage Air A/C bracket.The comp.did fit in the stock location,but I had to build custom alt. and tensioner brackets,which moved the alt. to pass side top to get it away from the steering box.I tried that A/C bracket set up on my 68 Camaro,and it didn't come close to fitting,but I am running an aftermarket sub frame.Looks like I going to be building some custom A/C and idler brackets.
Payton King
10-16-2006, 04:17 AM
before I switched to the 21st piece. Notched the subframe and it fit just fine. I was using the F body stuff that sits out further than the vette stuff.
ProBell
10-16-2006, 06:12 AM
Do you have a picture? What motor mounts did you use?
Thanks Randy
Payton King
10-16-2006, 12:47 PM
I could not find any photos because I changed direction and went with the 21st Century subframe. I did not like the way the oil pan hung 3/4 of an inch below the cross member so I raised the motor 3/4 in the car. I had to notch the subframe and cut an ear off of the compresor but it fit just fine. again I was using an f body balancer that is an inch or so futher away from the motor than a vette harmonic. I am sure there are other ways of doing it as some other companies have come out with brakets that use the really small compressor like on the front runner system.
FJB2069
10-20-2006, 06:53 AM
What balancer and crank pulley are you running?
Payton King
10-23-2006, 04:40 AM
Stock LS1 F body stuff
