View Full Version : Can I get 18X9 custom TTll's and are TTll's hubcentric?
moparguy
04-08-2006, 07:02 AM
Will American Racing make custom 18x9 TTll's and if so are all TTll's hubcentric made???
boosttoy
04-10-2006, 04:57 PM
They only make 18x10 and 18x8 ttII customs.I just ordered 18x10 rear and ft 17x9.5 for my nova.i dont think they make hub centric specific.I use et style lug nuts.They have a taperd seat and shank combo.This helps center the wheel off the bolt circle.
Later,Frank
tripower
04-11-2006, 11:09 AM
Later,Frank
You're able to squeeze an 18x10 under a Nova? Have the wheel wells been modified? Thanks.
boosttoy
04-11-2006, 06:04 PM
Tri,I have stock wheel wells except for trimmed lips.I currently have 17x9.5 6.375 back space with 2754017 tires.I have a .500 spacer and this works fine.AR does not make 18x9.5 ttII wheels so i ordered 18x10 with 6.250 back spacing with 2754018s.I will remove the spacers and i think they will slightley rub on the inner fender only on turns like turning in a driveway with short steep inclines.But not enough to damage the inside sidewall.Hard to believe but i also have 17x9.5 6.00 back spacing with 2554017s on the front of this car.These sizes are stretched to the extreme limits and i would advise against for most people.I just want to be a little bit extreme.Carefull measurement were made for these to fit.
The car has wilwood disc brakes,dse arms,a 12 bolt out of i dont know what,qa1 ft coilovers ect.Pics at www.hometown.aol.com/boosttoy
Later,Frank
