View Full Version : Killer 69 Update
killer69
04-04-2006, 11:11 AM
Here are a couple more pics ( the last 6 in the gallery)
will have more next week of the car together and on the ground
http://www.killercustoms.ca/images/gallery/69camarov3/11.htm
3 more weeks to finish it
Todds69
04-04-2006, 11:15 AM
Sweet...looking forward to those finishing pics.
BADVELLE
04-04-2006, 11:26 AM
Very nice!
tbair
04-04-2006, 11:46 AM
looks great.like the gas cap.are you going to use any other brushed pieces?
DJW32
04-04-2006, 11:51 AM
DAMN!!!!! NICE!!!!!
What kind of rear suspension are you going with?
Rybar
04-04-2006, 11:57 AM
Looks good Blake, when is the unveiling?
srh3trinity
04-04-2006, 05:09 PM
Love the wheel choice.
96Z28SS
04-04-2006, 05:27 PM
WOW that fuel cap is big.
ProdigyCustoms
04-04-2006, 05:41 PM
Looks Killer! Our Steve O really started a trend with that gas cap. I likes it!
CAMAROBOY69
04-05-2006, 03:34 AM
I noticed the entire bottom of the car is cut out. Where do you plan on mounting your license plate? I assume your exhaust will go where that opening is at?
killer69
04-05-2006, 08:53 AM
The rear suspension is a Morrison triangulated 4 link and it fits really nice just used the factory leaf spring mount and then a upper mount in the floor behind the seat.
Asfor the brushed aluminum NO most is either beadblasted and clear annodized or polished and clear annodized or black chromed.
I think the gas cap will be polished and clear annodized.
the cut out will have 2 exhaust tips on either side and the plate will be mounted between them and recessed back so it is less obvious.
As for steve o starting a trend hummmmmmmm not to knock Steve but i think GM did it on the 67/68 Camaros we ( meaning steve ,baldwin, us , and everyone else that has done it) have just tried to improve on it
CAMAROBOY69
04-05-2006, 09:05 AM
I just looked back at the pics and had another question. Since your cap is right in the center of the car and the exhaust is right under where the tank will be, I was wondering what you will do for a gas tank. I only ask because I was originally planning on running a cap like you did but my fuel cell would have had to be a lot lower. And my exhaust enters straight out the back directly under my fuel cell. I assume your going to make a tank for it that hugs around the exhaust pipes? Otherwise it will be too high to put gas into.
I mean the bottom of that cap is only about 3"-4" above the exhaust tips.
killer69
04-05-2006, 11:26 AM
that's a design secret ............... no really we cut most of the trunk out and built a tank that is now the trunk floor and the exhaust now runs where the leaf springs were and the mufflers mount on the side of the tank up where the rear spring mounts were. you should be able to see the exhaust in some of the pics on the site.
CAMAROBOY69
04-05-2006, 11:29 AM
Ohhhh I see it now. Very clever. You had the exhaust run beside the tank then out the center of the back. Dang thats killer! Wow even the mufflers are behind the axle. Impressive. Must have been tough to route everything but you did a great job with it.
