View Full Version : Measuring crank for straight. is this correct
LowBuckX
04-03-2006, 09:56 PM
After this thread https://www.pro-touring.com/forum/showthread.php?t=17212 I got out the dial indicator.
With center cap installed and measuring front journal I got on the small side of .001 maybe .0009 of run out.. Same on rear journal
With front and rear cap installed and center 3 out i measured the runout of center journal. it was nearly perfect. The .0001 needle barely moved.
Is there another way to check or is this correct.
If it is correct I think the crank is A ok.
Now to mic the journals.
LowBuckX
04-04-2006, 10:05 PM
I measured the main and rod journals today.
Mains All checked 2.6385 -2.639
Rods all measured 2.090- 2.0895
Not much taper or egg shape to mention.
LowBuckX
04-04-2006, 10:49 PM
Found both bearing problems.
Rear has no clearance
And front has a spun cam bearing
