LowBuckX
04-03-2006, 09:56 PM
After this thread https://www.pro-touring.com/forum/showthread.php?t=17212 I got out the dial indicator.
With center cap installed and measuring front journal I got on the small side of .001 maybe .0009 of run out.. Same on rear journal
With front and rear cap installed and center 3 out i measured the runout of center journal. it was nearly perfect. The .0001 needle barely moved.
Is there another way to check or is this correct.
If it is correct I think the crank is A ok.
Now to mic the journals.
