    Results 1 to 3 of 3
      Washington
      Rear Brake Caliper positioning. Help
      I haven't been able to find much info on the ideal position of the rear brake caliper, so here goes.
      I'm currently working on mocking up my rear axle. It's a custom full floating 9" with 12.5" rotors and Wilwood calipers. From what I've seen most rear calipers are usually put on the upper rear corner or near the 1:00 or 3:00 position of the rotor.
      Can anyone help guide me on this topic? Pro's, con's or ideas on why they might be better in one spot vs the other?
      Jake
      Dec 2002
      Lost Wages, Nevada
      It comes down to packaging and mostly where the shocks are going to be located.
      Some ideas around this subject are, putting the calipers on the leading (forward side) of the axle as it keeps the brakes (ie the weight of the components) in between the wheelbase for better balance. But on the 68, the weight would be better if they were put on the trailing (rear side) of the axle to offset the weight on the front end. It may be small, but every pound helps.
      Also on the 68, the shocks were in a staggered configuration from the factory..... that balances the weight right on the axle centerline.
      Really the issues that come into play is the positioning of the calipers to where they are not going to interfear with the leaf spring (or what ever suspension you will run), or interfearing with the shock, frame rail, spring perch or bump stop and keeping in mind where the bleeder is placed on the caliper.
      With a 9" I guess your caliper placement is going to be reliant on your shock placement. Start there and trial fit things a few times to see where are happy.
      Washington
      Yeah
      Thanks for the reassurance. That's along the line's of what i've been hearing. Just wanted to get some ideas from the rest of you Die hard pro-touring guys.
      Thanks again.
