Results 1 to 6 of 6
04-02-2006 #1
Some brake questions for the experts...
I have a 67 camaro with a bbc that weighs in at 3700 lbs+ with driver. I've got wilwood 13" 4 piston discs on front and big 11" drums on back. The car stops darn good for street use (as in right now) but it has a tendency on long road courses to fade before the 20 minute session is up, and use pads like holy cow.
It's a drop spindle setup, and I'm considering a larger rotor and 6 piston upgrade that will work better with less fade and fit with the 17 inch wheels up front, and if there is a good wilwood disc setup for the rear that will still allow me to run my 15" drag wheels? I am loking for a SUBSTANTIAL improvement in braking, so if it would just be a marginal improvement, I'll just make do. I already have a proportioning valve on my current setup.
I'm looking to be able to run much deeper in the corners for the whole session with this heavier car. Ideas????????
