View Full Version : 1st gen camaro motor mounts - rubber or poly??
BuddyP
04-02-2006, 07:37 PM
Which is better to use? Poly seems like it would hold up a lot nicer but would it put too much vibs through the chassis? I plan on doing a LS1 swap in a 1st gen camaro and want to use the proper mounts
Buddy P
chicane67
04-02-2006, 07:56 PM
Id use poly.... if for no other reason than that it has a safety built into it.
It wont transfer a real noticeable amount of vibration over a rubber mount. Unless youre used to a real loose and flexible stock chassis...... or a soft, pathetic little whiner.
~J/K~
I think you'll be fine using either but the added saftey and durability in the poly makes it a winner to me.
BuddyP
04-03-2006, 06:08 AM
Thanks! That's what I'll do!
