View Full Version : Where to buy electrical connectors?
Chevelle LT1
03-29-2006, 05:13 AM
Does anyone know of a good place, either locally in Phoenix, or on the net for buying electrical connectors (not the cheapie crimp connectors)? I need to start the Painless wiring for my car, and only want to do the job once, so I wanted to get the good connectors beforehand. Any suggestions are appreciated.
Jason
HzEmall
03-29-2006, 08:29 AM
if you want a safe bet on quality, go with 3M or Pico
I use all Pico uninsulated ones and use heatshrink to finish them off
EFI69Cam
03-29-2006, 01:28 PM
Jason
azconn.com
Chevelle LT1
03-30-2006, 06:05 AM
EFI69 -
Thanks a ton! That was exactly what I needed.
Jason
toxicz28
03-30-2006, 10:39 AM
Why not solder with heat shrink tubing?? Alot less problems with that, just a little more time consuming.
Chevelle LT1
03-30-2006, 10:59 AM
I was thinking about that as well. What I had really hoped to find was the shrink tubing butt connectors that also have the solder ring inside. All you do is heat the connector, and presto, you've got the shrink tubing and solder all finished.
If I can't find those, I will definitely be going the soldering route. Thanks for the suggestions.
eldogg
04-03-2006, 07:24 AM
Check out waytec wire. i think it is waytecwire.com but i'm not sure.
Eldogg
Queen City Speed
70 LS1
04-04-2006, 09:46 AM
Do any of these places sell the connectors without pigtails?
