View Full Version : Engine/hood clearance issue help?
formula
03-24-2006, 01:19 PM
Guys, I need your help on thinking up ways to lower my engine height just a little bit...like a half an inch at the most. I just need a little bit more clearance between the hood an the air cleaner.
All I've thought of so far is trimming the base off of my air cleaner. Any other ideas?
MikeDVC
03-24-2006, 01:32 PM
I trimmed the base of my air cleaner, pretty simple way of lossing 1/2 inch. Also try a shorter air cleaner element
CAMAROBOY69
03-24-2006, 01:48 PM
If you only need to gain 1/2" I would just modify the air cleaner. There are soo many sizes to choose from. Even if you got a shorter filter that could solve the problem. Any pics?
formula
03-24-2006, 02:58 PM
all I've got is generic engine pics....I tried to snap some that showed the clearance problem, but that's a wee tad difficult...since the hood has to be....closed :doh:
I have had zero luck finding a shorter element. I'm using an STP element for some random toyota something right now....
Since this shot, I've trimmed off as much of the air cleaner bolt as I can get away with.
PeteRR
03-24-2006, 08:14 PM
K+N makes dropbases for aircleaners. I'm using their 14"x3" with an 1.25" drop.
