View Full Version : first gen LS1 long tube headers
68redcamaro
03-19-2006, 07:14 PM
Just installed a set of Hooker long tube headers in my 1968 Camaro LS1 project this weekend. They fit great. If you are looking for a set of long tubes here are some pics that might help.
https://static1.pt-content.com/images/pt/2006/03/DSCF0668-1.jpg
https://static1.pt-content.com/images/pt/2006/03/DSCF0667-1.jpg
https://static1.pt-content.com/images/pt/2006/03/DSCF0666-1.jpg
https://static1.pt-content.com/images/pt/2006/03/DSCF0665-1.jpg
Van B
03-19-2006, 07:28 PM
Do you have a shot of how low they hang underneath? Are they tucked up nice higher than the subframe?
68redcamaro
03-19-2006, 07:49 PM
I will get a shot of that soon. They hang about 1/2" below the subframe. They will have very good ground clearance.
19topless69
03-20-2006, 09:05 AM
Did you use the Hooker mounts and S&P notched oil pan?
They look good.
Damn True
03-20-2006, 10:12 AM
Yes, please supply a photo of the "dangle".
68redcamaro
03-20-2006, 04:16 PM
Yes i am using the hooker mounts with the f-body oil pan notched by S&P. Clearence between the firewall and right head is 3/8". Here are some ground clearence pics.... hope they help.
https://static1.pt-content.com/images/pt/2006/03/DSCF0673-1.jpg
https://static1.pt-content.com/images/pt/2006/03/DSCF0670-1.jpg
https://static1.pt-content.com/images/pt/2006/03/DSCF0669-1.jpg
patriot68
03-20-2006, 07:38 PM
how much and where did you get them??:cool:
68redcamaro
03-20-2006, 08:09 PM
Anywhere that sells Hooker..... Summit has them P/N 2288-1HKR for $615.00 coated.
Ralph LoGrasso
03-20-2006, 08:18 PM
Speed Inc (www.ls1speed.com) a site sponsor has these for $579 coated.
https://www.pro-touring.com/forum/showthread.php?t=14273
my69rocks
03-21-2006, 09:16 AM
A great picture of the steering box area makes it look like thier would be no clearance issues.
Will they work with a Steeroids rack and pinion setup?
Are there O2 bung holes provided?
Rybar
03-21-2006, 10:28 AM
Great photos Terry, thanks for sharing. Can you check one more measurment for me? I would like to know how high or low the motor sits in the car. Maybe you can check from the top of the manifold to top of the firewall or something?
Ryan
patriot68
03-21-2006, 10:50 AM
we need a group purchase!!
zman1969
03-21-2006, 02:36 PM
anyone know if the offer for the BRP installed postion? engine moved up a inch or inch and a half? or am i stuck with stainless works? course theyre not much more :Alchy:
68redcamaro
03-21-2006, 08:25 PM
Ryan
From the top of the intake to the lip of the firewall is 4". There is more clearence between the subframe and the oil pan than SB350 had. Let me know if i can help.
Terry
68redcamaro
03-21-2006, 09:01 PM
The header come with collectors that have O2 bungs in them
my69rocks
03-23-2006, 12:14 PM
It looks as if the collectors are the type you need to weld on as I don't see them on the end of the headers in your pictures. Is that correct?
68redcamaro
03-23-2006, 05:54 PM
No, they slip on the end of the header and reduce to 2 1/2". I did not have them on in the pics. You just use a band clamp style clamp or you could weld it if you like.
my69rocks
03-25-2006, 08:49 AM
Great. Thanks so mush for the info and the great pictures that go along way!:usa:
any more news on the fit? what trans are you planning on running? T56? auto?
68redcamaro
07-06-2007, 08:01 PM
I used the 4L60E. I am very pleased with the fit. After installing different kinds of headers over the years in Camaro's I thought they fit better than any I had put in with a genI SB.
Terry
everyone seems to be concerned about how close the engine is to the firewall with the hooker mounts. when i look at my current gen1 engine in my 69 the lakewood bell is really close to the firewall. im not even sure if i could drop the bell in the car or not.
Leadfoot1
07-07-2007, 05:01 AM
Cool,
i have the Hooker plates and Headers in their boxes in the garage and have yet to test fit. Glad to see the steering box fits this good (seems to have ample clearance) As i was under the impression i'd have to whack the ceramic a bit from another thread i read after buying!!! You make my day!
Lead.
Oh, i got the Moroso pan tough....
i forgot to ask. what brackets are you running on your ls1? march?
Project69
07-07-2007, 03:16 PM
How did you mount the 60E? What corssmember did you use? did you have to fab anything up?
Thanks, Im in the middle of collecting all the installation parts to do an LSX swap. My dad said he'll buy me a motor once i finish the fire academy..........i think an LS7 is more fitting huh? lol
Dave95Z28
07-07-2007, 04:11 PM
Besides the ATS headers, does anyone know of a 1 7/8" header that fits a first gen with LSX.
Dave
Rybar
07-07-2007, 10:58 PM
Scott from Lateral-G is running 1-7/8 Kooks Headers on his LS7.
http://www.ls1tech.com/forums/showthread.php?t=739100&page=1
Not sure if they were custom made or not.
everything seems to fit when you dont run the factory power steering box.
68redcamaro
07-08-2007, 08:39 PM
S&P brackets
68redcamaro
07-08-2007, 08:42 PM
How did you mount the 60E? What crossmember did you use? did you have to fab anything up?
I used the Camaro TH400 cross member. I cut the mount pad off and welded on the oppisite side.
