View Full Version : where to buy 9inch for 67 firebird?
justforfun
03-12-2006, 08:34 AM
Are most people welding on the leaf spring pads themselves?
Or are people buying them complete from places like Currie?
parsonsj
03-15-2006, 05:41 AM
Welding on leaf spring pads will warp the housing tubes. It may or may not be a problem, so you should have the housing checked and straightened if you weld on the pads. Reputable companies like Currie, Moser, and Williams can supply you with a straight housing with the pads already welded.
jp
Tom Welch
03-18-2006, 08:35 PM
If you can find the 9-inch from a 65 Thunderbird then consider yourself lucky 2 times, first, you found one and second, it fits first gen f-bodies.
speedster
03-19-2006, 05:30 AM
I have a '68 Firebird. I purchase the Ford 9" from DTS since they will get the best pieces built for you particular application. (e.g. A Currie housing, a Strange centersection, a Detriot Locker....)
justforfun
03-21-2006, 04:51 PM
speedster, I remember seeing the pics of your car. wish the vbGarage was back up to look again.
Lowend
03-21-2006, 05:48 PM
The Moser is so well done it bascially installs itself
whytry
03-22-2006, 09:07 AM
I like the Chassisworks Fab 9 personally....
rockdogz
03-22-2006, 12:52 PM
That's what I chose...
speedster
03-22-2006, 01:31 PM
Here is a low res version of the 9in Ford for a 68 Firebird with DSE QuadraLink mounts. Hope it helps.
Steve68
03-22-2006, 07:59 PM
I know someone who has one for a 69 Bird,PM me if your interested
chevy garage
03-24-2006, 05:54 AM
I bought a complete 9 inch out of a 70 Mustang. Bolted right in my 68 Camaro. About 1/2 in narrower than stock Camaro rear.Re-drilled axles to Chevrolet car pattern. Easy swap.
