View Full Version : Nova question..
RobM
03-11-2006, 06:45 PM
Does a 76 nova share the same suspension as earlier nova's or the camaro? does it have the 8.5 inch 10 bolt?
Bill Howell
03-11-2006, 06:47 PM
Yes on the suspension, and I am pretty sure yes on the rearend too.
RobM
03-11-2006, 07:13 PM
just what i wanted to hear, i knew it looked close but i needed to know for sure
zbugger
03-11-2006, 07:19 PM
I believe the 76 Nova is similar to the 70-81 Camaro front suspension. The rear end should be an 8.5". They installed it in almost everything during that time.
Bill Howell
03-11-2006, 07:23 PM
Maybe Allen, but if so, when did they change from the old style? 75? 76?
68-72 was the same and I feel sure thru 76or77 was the same as the 68-72
I am thinking they used the same front end suspension until they changed the bodystyle. Then I have been wrong before....
zbugger
03-11-2006, 07:48 PM
First year on that body style for the Nova was '75. '68-'74 was the same chassis.
Bill Howell
03-11-2006, 07:58 PM
Thanks,that was the Hatchback years?
decent new website on novas
http://www.novas.net/forums/
RobM
03-11-2006, 11:34 PM
this is a different body style from 72-74 but its not a hatch back, the suspension looks just about the same as my 67 camaro though, this car is cherry and im getting it for 700 bucks so im wondering what kind of potential it has
zbugger
03-12-2006, 12:02 AM
Rob, what does the spindle look like? One piece or the upright with a bolt on steering arm? Oh, an is it front steer or rear steer?
RobM
03-12-2006, 12:18 AM
i have to look at the car again all i know its the controll arms look very much like my 67, now im kicking my self for not looking more closely
Chevy350
03-12-2006, 04:26 AM
I friend of mine has a '75 Nova 2door - It's the first year 4th gen X-body, and shares the FRONT suspension with the 2nd gen F-body - Tall spindles, same UCA/LCAs, 5.5" diameter springs, and front-steer. You can see his car in the homepage listed in my profile, his name is Jarle (Just say Charles if you can't pronounce it :))
Bill Howell
03-12-2006, 05:30 AM
Rob,
Look at the steering, is it front or rear steer. ( Is it in front of or behind the cross member.) That will tell the tale.
EDIT, sorry I did not read the two above posts before I posted. :hammer:
69bigblock
03-12-2006, 06:35 AM
What I've found is that the rear diamensions are the same from 68-79
http://www.novaresource.org/axle.htm
As for the front, I know the front frames are the same 68-74.
not sure if the arms etc. are the same as the 75-later. Pretty sure that the steering is front steer. You could also check out.
http://stevesnovasite.com/forums/index.php
Chevy350
03-12-2006, 07:34 AM
I can confirm that the front suspension on my '77 Caprice, my friend's '75 Nova and another friend's '70+'71+'79 Firebirds/Trans Am all share the same LCAs and tall spindles. The only differences over the years are that the bushings in the lower CAs have gotten bigger (bolts too), and the balljoint mounting angle have changed on the upper CAs. They all have the same upper and lower BJs. The subframes themselves are not identical between Nova/F-body, and to what I've heard do not bolt in to each other. The geometry part is still more or less identical, and mods that work on the F-bodys work on the X-body as well.
For the rear suspension, I can confirm your finding on the rear axle 69bigblock, as the leaf mounting width differs between the '75 Nova and the F-bodys I have measured. My question now is this - What leaf springs does the '75-'79 Nova use? The ones for the 1st or 2nd gen F-body? The lowest lowering springs I've found for the 2nd gens are only 1.5", while 1st gens have 2" and 3"...
Sorry for the thread hijack, It's just all interrelated here.
RobM
03-12-2006, 01:14 PM
hmm this is going to be tricky, im wondering if maybee i should just build a tube chassis for this car and be done with it :ssst:
Chevy350
03-13-2006, 09:20 AM
Why? In stock form the '75-'79 Novas front clip is better than the elder ones, and need less modifications to be as good as a bolt-on '68-'74 will get. I'd do the normal upgrades to it, and enjoy :) The support for 2nd gen suspension is growing day by day, and prices are getting better. While a WELL executed tube chassis might be better, I don't think the price would be defendable - even if you do all of it yourself (and then, questioning your fab'skills, technical knowledge, and the possibility to pull one off at all - and still might end up with something heavier, less rigid, and just way more expensive than the upgraded stocker) Is it worth it?
By all means, for that price - buy the car! Enjoy it in every way possible, you don't see them around as much anymore.
RobM
03-13-2006, 03:50 PM
i have training in chassis fabrication. I’m not sure what I’m going to do how ever i may just keep this one simple. The suspension isn’t such a bad designee and i think i can cure most of its flaws. What I’m going to do in the mean time is completely rebuild what’s there from ball joints to shocks to brakes and get a solid driving car for a base
RobM
03-13-2006, 07:34 PM
what would you say nova of these years would weigh?
Chevy350
03-16-2006, 02:20 PM
Then you know what is involved, and how much work it is. I still think it's a "waste of time" on a disco-Nova, but it depends on plans of use, etc. By all means - do what you feel is best, but for that price, please save that car ;)
My friend's car has 3700lbs written in the registration papers (1690kg), which I find quite heavy... But maybe it's correct - we haven't weighed the car yet. It's an 250cid L6 and TH350 btw.
RobM
03-16-2006, 06:49 PM
Yeah I was half kidding about the tube chassis thing, 3700 does seem a bit heavy for that car, the car is a line 6 with a th 350. can i just use second gen camaro frame mounts to put a small block in? This car is going to be very budget.... plans are a mild small block (350 hp) Turbo 350. complete rebuild of all suspension and brakes, Mild suspension upgrades, frame connectors, custom (low key) interior by me, paint by me. I want a reliable car that I can take cross country in good comfort. Will handle decent and have good power. and last but not least I want to be able to park it at the mall and not have to worry about some one messing with it.
Chevy350
03-17-2006, 04:54 AM
The clamshells on the subframe are the same as the V8, so you just have to get the correct length/width outer shells on the V8 block. Worst case scenario, you have to move the mounts on the subframe some (multiple holes drilled already), but it's no big deal.
I have a 400cid SB lying around that my friend is going to borrow from me this summer, so we'll have the same swap coming up this spring :)
BonzoHansen
03-17-2006, 06:46 AM
There were some minor changes to the 2nd gens over the years, and I forget the exact break year, but I thought I’d mention it. The sub frame changed, probably in 75, for clearance room for the cat. The lower control arm bushing size changed, maybe in 73, but I am fuzzy on the details. I am unaware of any change to upper control arms.
Maybe search http://www.nastyz28.com/forum/index.php for more info.
1977nova
03-17-2006, 10:07 AM
I did the l-6 to v8 swap on my car. The small block fit perfect with no need of changing the mounts.
Slow Ride
03-10-2007, 06:25 PM
I know this is an old thread, but I'll revive it. I am working on a '77 Pontiac Ventura. What started as a simple engine swap as grown out of control. I am looking to see if the tall balljoint will help when I reassemble the front subframe. Here are some pictures for everyones enjoyment...
https://static1.pt-content.com/images/pt/2007/03/DSCN0447-1.jpg
https://static1.pt-content.com/images/pt/2007/03/DSCN0448-1.jpg
https://static1.pt-content.com/images/pt/2007/03/DSCN0455-1.jpg
https://static1.pt-content.com/images/pt/2007/03/DSCN0456-1.jpg
https://static1.pt-content.com/images/pt/2007/03/DSCN0461-1.jpg
and the reasons for all of this fun...
toasted subframe bushings ( here are the bolts)
https://static1.pt-content.com/images/pt/2007/03/DSCN0449-1.jpg
and the core support was completely rusted. the body bushings were long gone.
https://static1.pt-content.com/images/pt/2007/03/DSCN0450-1.jpg
https://static1.pt-content.com/images/pt/2007/03/DSCN0451-1.jpg
