View Full Version : Gas Tank for '68 Camaro LS1 Conversion
ItDoRun
03-09-2006, 01:46 PM
I just finished pricing the Rick's gas tanks from Jeg's, and although they are extremely nice, there has to be a much cheaper route. I was thinking of buying a repro tank and modifying it. What parts do I need to do this (fuel pump, regulator, etc.)? I would like to mount the pump inside the tank,if possible. Also, are there any sketches or drawing out there where people have modified original tanks like this. I know Tony Whatley went this route. Tony, you out there? Thanks in advance.
Chris
Rybar
03-09-2006, 02:51 PM
There is some info and pics in this thread of what you are asking about: http://www.ls1tech.com/forums/showthread.php?t=435704
Hope that helps.
Stu Seitz
03-09-2006, 09:16 PM
I used that stock pick up and drilled another 6-an hole in the tank. Then I used a 6-an fitting with nylon washers to act as a connection for the return line.
JMitch19
03-30-2006, 02:02 PM
For some reason the link doesn't seem to work...
Rybar
03-30-2006, 02:12 PM
Try this one: http://www.ls1tech.com/forums/showthread.php?t=472609
JMitch19
03-30-2006, 02:29 PM
Yep, that one is up and running.
