View Full Version : fiberglass body questions
rb70383
03-09-2006, 08:56 AM
How does one go about making a fiberglass body? If I was to make a car from scratch it would have to be this one. The Wraith (www.thewraithcar.com)
kennyd
03-09-2006, 10:32 AM
i have had experence making a glass car , it took us about 14 months to make the plug and finish it for a mold to be pulled then about 6 months for the mold then about 3 months for the 1st body .
i would be hard to explain how to build it on a web site you need to visit a glass body builder and see 1st hand .
rb70383
03-09-2006, 11:32 AM
I kinda figured it would be a little to involved to explain online. :) Did you look at those pics? Is that a glass body?
High Plains Mopars
03-15-2006, 06:18 PM
Typically you have to make a mold, which is a negative image made off the original parts. It is pretty involved to create. New parts are then cast out of the mold.
Without access to the original part to create the mold, you might have to carve the part in foam, then cover it with fiberglass and work it smooth like typicaly body work while making sure you add mounting hardware and the like in place as you go along.
boodlefoof
03-16-2006, 02:03 PM
I've basically made a moldless construction (or you could call it a male mold rather than a female mold).
Didn't do the whole car, but easily could do it this way...
http://www.geocities.com/boodlefoof/Project_Racer-Zfiberglass.html
Also, check out www.fibreglast.com Lots of good info over there and all the products you will need.
rb70383
02-13-2007, 02:50 AM
Also, check out www.fibreglast.com (http://www.fibreglast.com) Lots of good info over there and all the products you will need.
Any updates on the this. :twothumbs
maro67
02-13-2007, 04:15 AM
That Is Not The Corrcet Way To Make A Fiberglass Body/panel/etc...
rb70383
02-13-2007, 07:54 AM
Well this is a thread we I'm asking for ideas. So cough 'em up. :)
