View Full Version : Nonpro-touring related 4l80e?
EFI69Cam
03-08-2006, 06:24 PM
I have a 99 vortec 454/2wd 4l80e that I want to install in my winter toy 91 k5 Jimmy 4x4. Does anyone know if I can go to Chevy for the piece that goes between the trans and the tranfer case? The T-case is an NP241. I know I will need to have the output shaft swapped.
Has anyone done anything like this?
myclone
03-09-2006, 03:47 AM
Im not aware of any GM xfer case to trans adaptor that will bolt that xfer case to an 80E. There are a hand full of companies that offer conversion kits from a Th350/700R4 to an TH400 which is the same as the 80E as far as the components you need (output shaft/tail housing bolt pattern, etc).
Heres one that Im aware of and Im sure Advanced Adaptors has something as well.
http://www.powerandperformancenews.com/store/merchant.mvc?Screen=PROD&Store_Code=TC&Product_Code=229901&Category_Code=
HTH
bonesfab
03-09-2006, 09:35 PM
I put a 4l80e behind a 205 t-case. took minor machining to get the register ring to seat on the gm adapter. upgrade to the 205 case much better unit.
Beastus_Maximus
03-19-2006, 09:33 AM
I agree that the 205 is a much better T case, what I would aso sugjest is that you look up advanced adapters because I would almost bet cash money that they make the piece you need to addapt the 2 and it would be a bolt in. Good luck with the blazer, sounds like it will be a nice rig. I actually have a 89 myself, I love the things.
EFI69Cam
03-19-2006, 10:59 AM
I appreciate the advice. I think I will stay with the 241 for now. I don't do any rock crawling, nor will I put bigger than 33" tires on the truck, so I don't think I need the stronger cast iron 205.
I don't see any 241 to 4l80e adapters on advance's web site, but I think the late model trucks had 4l80es and 241s.
