JEFFTATE
03-08-2006, 11:55 AM
I have a 1969 Camaro with a small block,saginaw 4-speed, and 12-bolt rearend. I've been having a problem with vibrations. Feels like a driveshaft vibration or a loose pinion nut. I had the car on a lift the other day and someone said that my driveshaft didn't appear to go far enough onto the output shaft of the trans. How far should it go on ? The car is a bit of a Frankenstein. It has a 1970 truck block, 1970 Nova rearend, and 1976 Saginaw transmission. If I need a new driveshaft, what is the proper way to measure for length,etc..? And how far should the driveshaft slip yoke go onto the trans output shaft ?
