View Full Version : TKO 600 ?'s
kman67rsss
10-06-2004, 06:26 PM
I remember seeing a picture that identified the three plugs on the side of the tranny. can someone point me back there, or identify them for me. also i remember seeing a neutral switch. how does this one work, i ask because i have wires in my painless kit that are identified as neutral switch and am wondering if this one on the tranny will work, or if i would be better off rigging one up on the clutch pedal. thanks
Hurst - Jeff
10-07-2004, 06:47 AM
kman67RSSS-
Driver's side mid case - reverse light switch (two brass studs).
Driver's side tail shaft - neutral safety switch (wire harness with plug).
Passenger side - electric speedo pick up (black plug in).
On the neutral safety switch, if hooked up with your Painless wiring, the car should start only when the shift lever is in Neutral.
I hope this helps.
kman67rsss
10-07-2004, 06:59 PM
thanks. that helps a lot
mjpell
10-14-2004, 10:57 AM
Here's a tech write-up for using the servo switch as a neutral safety switch:
http://www.5speedtransmissions.com/neutral_safey_howto.html
That's a low-amp switch, so be sure to use a relay! Hopefully your Painless harness already has one.
Mike :revto9k:
