LS1_78Bandit
03-07-2006, 08:28 AM
This was sort've buried at the end of my "wheels for 78 t/a" thread. I thought it might help to pull it out to its own topic.
How much leeway should I leave for movement both laterally and vertically?
I just spent about 4 hours pulling my wheels off and measuring things in just about every way imaginable. Now I need to turn that info into "what to get".
I think the answer is going to end up being the 10.5". On the left rear, my total clearance from the shocks to the inside of the fender lip is 11.5". That would mean a tolerance of about 0.25" on either side of the wheel unless I either roll the fender lip or assume that the body will not come down far enough for the outside fender to be an issue. With my current suspension that's a reasonable bet, but with all the new suspension parts going in, it's possible it will be an issue.
And I'm glad I followed everyone's advice and measured both sides. I had more like 12.5" of clearance on the right side. I think that the left side fender was replaced during the restoration which might explain the difference - or it could just be "situation normal".
UPDATE: I was talking to the salesman that's selling me the rims and he was saying that there is a 0.75" lip on either side, so the true width of a 10.5" rim is 12". Does this make sense?? I thought that when a rim was listed as "17x10.5" that the width was actually 10.5". If the true width is actually 12", I'm not sure I can even fit the 10.5" rim ... Harumph.
