View Full Version : ls1 brake swap...what prop valve and m/c
importkiller69ss
03-06-2006, 09:19 PM
i have all the parts mounted all i need to know is will my master cylinder and booster be ok...it is off some kind of 70's vette i bought it new from napa....also will the adjustable prrop valve from summit be ok...any advice...what would be best....
importkiller69ss
03-07-2006, 03:10 PM
any one know if the sumit prop valve will be ok if it wont which one do i need.....i have one off a 2nd gen t/a front disc rear drum on there now can i still use this
importkiller69ss
03-07-2006, 04:53 PM
would the m/c from the donor car of the brakes work...and would it bolt up to my booster
68BNUT
03-08-2006, 12:34 PM
Do you still have drums on the rear of your car? If you do and you already had disc/drum combo valve on your car then the old valve will work. If you had drum/drum then you should remove it and use the summit valve to adjust your brake bias.
Im not sure if the master cylinder that you got will bolt directly on to your car now, I would assume so though. Only one way to find out.
importkiller69ss
03-08-2006, 01:48 PM
well the booster and m/c is already on the car hs been for a bout a year...was on there with stock disc/drum....so my valve will work with my ls1 front and drum rear until i decide to do the rear ls1 swap then would have to get the summit valve...right
ItDoRun
03-09-2006, 02:07 PM
If you have an extra $125, go buy a Strange Dual Tandem Master Cylinder (1" bore) and a Wilwood residual valve from Summit. Those proportioning valves can cause nightmares. If you are running drums in the back, buy the red valve and if you are running discs in the back buy the blue valve. Oh, make sure you get the valve with the inverted flare fittings. Wilwood offers this as a combo.
Chris
ItDoRun
03-10-2006, 05:31 AM
Forgot to mention that you will need to slot the bolt hole pattern in the master cylinder for it to work on a GM car. Are you planning on running manual or power brakes?
importkiller69ss
03-10-2006, 07:01 AM
power what do you mean to slot te bolt pattern
ItDoRun
03-10-2006, 10:33 AM
The bolt holes on the master cylinder are not made for GM applications, therefore you need to make the holes slotted to fit over the firwewall mounting studs.
03-10-2006, 09:55 PM
Ive used a 3rd gen (disc/drum) master and combo valve with no problems. My latest job im just using a 3rd gen combo valve with a vette 1" master and stock style booster.
