87SS
03-05-2006, 06:11 PM
looking at this set up for my 87 Monte SS... input? (I know it's no 69 camaro :poke: but humor me ok...)
https://static1.pt-content.com/images/noimg.gif (http://cache.speedwaymotors.com/eccStoreFront/product_images/Jess%20Tester/25255_R.jpg)
http://www.speedwaymotors.com.169/qx/Product.htm (http://www.speedwaymotors.com/xq/aspx/dept_id.158/display_id.169/qx/Product.htm)
https://static1.pt-content.com/images/noimg.gif (http://cache.speedwaymotors.com/eccStoreFront/product_images/Jess%20Tester/91645551_R.jpg)
http://www.speedwaymotors.com3389/qx/Product.htm (http://www.speedwaymotors.com/xq/aspx/dept_id.157/display_id.3389/qx/Product.htm)
I was thinking of using the 600# or 650# spring.
This would give a min. 12 5/8" & max. 14 3/4" inital free spring height .
A stock Monte SS spring has a 14.65" free spring height. And a 420 lb./in spring rate.
Actually I was thinking of welding the adjusters in the upper pockets while I have the frame stripped & upside down. I understand the adjustment issues with this plan.
If I were to install the adjusters in the lower pockets (an Idea I really don't like) wouldn't I need to grind/cut a helix in the adjuster to comform to the lower spring pocket?
Like I mentioned I was planning on either using 600# or 650# front springs. What rear spring rate should I consider? I am thinking 150-175#
And how about mod'ing the rear spring locations to accept a 5" dia spring and adjusters for the rear? like the above adjusters & 252510-175 5" X 10" REAR TRU-COIL SPRG (http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.158/display_id.165/qx/Product.htm)This would give a 13 1/8" min - 15 1/4" max free height spring.
Again a stock Monte SS rear spring has a free height of 14.75" and a spring rate of 121Lb./in
