View Full Version : 1st Gen mirror position?
Damn True
02-24-2006, 06:35 PM
On the 1st gen Camaro is the passenger side mirror mounted in the same place as the drivers side? My car currently only has the drivers side. I recently found a set of mirrors (driver & passenger) that I am going to run.
Ive seen some cars where the mounts are in different places to accomodate viewing angle.
Railing68
02-24-2006, 07:23 PM
I just bought one for pass side and according to the shop I bought it from, I might need to alter the stock location to be able to see. SS
02-24-2006, 07:26 PM
If it's a 67, you need to check that the pass side vent window isn't in the way. A 68/69 is probably the same as the driver's side. I wonder if it's in the GM assy manual?
awr68
02-24-2006, 08:34 PM
True, mount them in the same location. I start with the drivers side and center the remote cable in the 1" hole in the door...then measure and locate the pass side mirror.
