View Full Version : Disc Brake Help 67
67drop
02-22-2006, 04:16 PM
I have a 67 convertible camaro rs that i am currently in the process of building up. I also bought a donor 97 ws6 trans am w/t56, the trans am has a baer sport brake set up on the front. What I would like to do is swap this to the 67. The 67 has a fatman complete subframe with dropped spindles mustang rack etc... Is this swap for the front possible? Also I have the stock 67 front disk brake and caliper assy. Will I only need the bracket and rotors(which i plan on replacing anyway)? I would like to use the petal assembly from the 97 inc brake booster as the 67 has none. Also will the rear brakes from the 97 mount to my 67 12bolt? ALSO does anyone have any info on a hidden brake booster system as I would like my firewall as smooth as possible.
derekf
02-22-2006, 06:21 PM
The rear brakes will bolt up.
The front brakes should bolt up but I am not sure what brackets you will need to get to adapt them to your existing spindles.
Can't help you any on the brake booster.
LTorres
02-23-2006, 10:47 AM
MadMax from these boards is installing a hidden booster on his first gen. I haven't seen him post in awhile but I am sure if you PM'ed him he would give you the details on how he go the parts (decent pricing) and how he plans to install it.
