View Full Version : Power steering cooler question. (yes I searched)
LowBuckX
02-19-2006, 12:05 PM
1) can I convert my old small tranny cooler into a power steering cooler? Found answer to this which was yes as long as it is a tube type which I have
2) would you hook up a steering cooler to the low or high pressure side?
Only answer I found was by Yody which was Low side But there was no confirmation or rebut.
zbugger
02-19-2006, 12:18 PM
Both of the answers you found I have also found to be correct. The low pressure side is the return line, and that's what you want to be cooling.
02-19-2006, 04:45 PM
Yes and yes. High pressure can be 1300 psi, that would blow up a cooler! Cool the return flow.
