View Full Version : hydraboost new or used
FJB2069
02-16-2006, 06:39 AM
Has anyone adapted a used hydraboost on a 69, and if so out of what car?
rlovell383
02-21-2006, 07:32 AM
I have done it, as well as some other people. Check out carl casanova's web site. Unless you have very good fabrication skills I would not recommend it. It is NOT an easy weekend project: i probably have 100 hrs of work in mine between research and fabrication to make it look factroy clean, but the payoff is out-of-this-world brakes. Honestly, if I were to do it again I would just buy the Hydratech setup. You don't save more than maybe 150-200 dollars and theirs will bolt in with a couple beers worth of work.
Randy
ilovefirstgens
02-21-2006, 10:51 AM
i second hydratech, absolutely amazing customer service and a dynamite product!
LTorres
02-21-2006, 04:57 PM
I'll third that......everyone I have set up with BBK's running or even mentioning a Hydroboost has dealt with Hydratech and given rave results. Two thumbs up!:jump:
protour_chevelle
02-21-2006, 06:28 PM
I did my own. For the ease of no swearing, no phone calls, no headaches.... Your better off with Hydratech. However if your a junkyard rat.... Do it yourself :)
-Matt
Orngcrush69
02-21-2006, 07:34 PM
I fifth that, Paul is the only way to go. I tested 60-0 braking and came in at 135 ft.. That's with a C-5 braking system with hydra-boost.
1970cuda
02-21-2006, 07:37 PM
save yourself any nightmares and just call paul. you will be time and money ahead in the end
indyjps
02-22-2006, 01:09 AM
i tried to get a price quote on a complete system less braided lines ( i can make them @ work ) and never got a response. i may try again, has anyone done a partial kit.
Hydratech®
02-22-2006, 09:54 AM
Hi Guys! I just happened to be lurking through and read all of your awesome feedback! Thank you so much, as we REALLY work our tails off to produce the best possible systems for you.
Are you sure that you put your inquiry in to us here at Hydratech? We have a policy of answering each and every e-mail. If we did indeed miss your e-mail somehow, then I truly apologize!
FYI - When you are looking at our online listings, the "lineset delete" option = the assist unit itself without lines...
:cheers:
Steve68
02-23-2006, 03:03 AM
Paul has returned all my e-mails!!
