View Full Version : Hydratech w/T56 bracket
scogin918
02-15-2006, 05:17 PM
Has anybody with this set-up used longer bolts through the firewall? It seems that once you have the firewall bracket on that there's not that many threads left on the bolts that come from the pedal assembly through the firewall.
datsbad
02-15-2006, 07:22 PM
i did not replace them . mine worked fine as stock .
what did you end up doing with the ac?
scogin918
02-16-2006, 04:12 AM
I notched the subframe for the stock compressor to fit. I now have the Sanden compressor to take its place, but I haven't tried to install it yet.
datsbad
02-16-2006, 06:10 AM
give me some info here , who's motor mounts? what steering?
I just did this and it does not work without getting into strength integrity of the subframe .
thankfully i cut one large hole with the plasma, i was able to put it back , and never know i cut it .
i used S&P mounts and dse steering. vintage airs bracket for f body LS1 and sanden 508 compressor . the back of the compressor will be right inline with the motor mount stand that bolts to the frame . pm me if you like !
