View Full Version : Which SS brake lines do I need?
Brandon
02-14-2006, 10:30 AM
I am installing C4 Vette ('88-'94) front disc brakes and LT1 ('93-'97) rear disc brakes on my 1969 Camaro. What Stainless Steel brake lines do I need to complete this swap?
Will the '69 camaro stock cable fit the rear setup listed above?
I have no problem making/using new flare fittings (single or double).
Brandon
Norwoodx55
02-14-2006, 06:47 PM
Dude, just call Laramie Torres at Precision Brakes 866-992-7253. He has the lines to do what you want. The problem is the brakes you are using have bubble flare fittings and your car has double flare fittings. I am in the middle of a similar brake swap and he got me hooked up with the right lines. He knows the correct lengths and fittings for each end of the lines.
Brett
Brandon
02-15-2006, 07:51 AM
Brett,
Thanks for the tip! This is just the info that I was looking for.
Brandon
Norwoodx55
02-15-2006, 06:43 PM
Not a problem. :twothumbs
69camarodave
02-24-2006, 07:29 PM
Laramie is the man he hooked me up with the lines also!
