View Full Version : 70 Chevelle Drop Spindles
InMotionJosh
02-08-2006, 08:19 PM
I am planning to run the Air Ride Tech suspension on my car with the upper and lower a arms and shockwaves in the front. I am thinking that it might be a good idea to run some 2 inch drop spindles to keep the ride height down.
I need to know what are some good spindles to run. What do you recomend. Anything to watch out for or stay away from?
indyjps
02-08-2006, 09:05 PM
you will have quite a bit of adjustability with your air ride system, have you contacted them about recommendations. how low are you wanting to go?
InMotionJosh
02-08-2006, 09:09 PM
I know the car will go low with the air ride. Thats not the problem im worried about. I want the ride height to be just right and still ride smooth. If the stock spindle is to high and the bags are at a low pressure at ride hieght it wont ride well, same if the spindles lower the car too much the pressure in the bag will be to high and cause a stiff ride. Im looking for that happy medium.
