View Full Version : new electronic transmisson to a BOP
Pro-touring towncar
02-05-2006, 09:45 PM
I am working on getting a buick and would like to put in an electronic transmission in it. Does anyone one know if the new trannys have the BOP bolt pattern,am I looking at an adapter or just SOL. I am wanting an electonic transmisson so I can use the paddle shifter on it and have O/D.
Tim
Steve Chryssos
02-07-2006, 06:31 AM
Tim,
Give Bowler Transmissions a call and ask for Mark. Says an adapter for that application is about $240. Crank to flexplate spacer, bellhousing adapter and hardware. Please tell him that Steve at Twist Machine referred you.
http://www.bowlertransmissions.com/
RR#4 Box 148
Lawrenceville, IL 62439
Main Phone: (618) 943-4856
Fax : (618) 943-3690
nekkidhillbilly
02-08-2006, 09:39 PM
200r4
nekkidhillbilly
02-08-2006, 09:42 PM
200r4 usually have both patterns....they make adapters for chevy to bop ........what kind of buick if its a nailhead you will have to have and adapter for any other tranny
......look at v8buick.com they have all the infor on buicks you need
GetMore
02-09-2006, 04:00 PM
The 200-4R is not electronic. I don't think there are any BOP pattern electronic transmissions.
Jagarang
02-09-2006, 09:22 PM
...and thank you Steve for the refferal.
I called Mark at Bowler and ordered an adapter and a pan for the 4L80E I'm putting into "Eternity". Now I need to find a neat way the shift that same tranny....hmmmm :ssst:
nekkidhillbilly
02-15-2006, 07:49 PM
my bad it an od just not full computer controlled......the tcc is electronically controlled
for a 350/400/430/455 you can use those adapters under 100 bucks from summit jegs etc
401/425 cost about 350 bucks www.transmissionadapters.com (http://www.transmissionadapters.com) or www.nwspeed.com (http://www.nwspeed.com)
