WS6
02-05-2006, 07:05 PM
i thought maybe i had an odd problem but in doing some research i found someone else who mentioned having a similar sound, but they really didnt say what the problem was. so heres what is happening to me and everyone can give their best guesses.
the car drives and shifts perfectly fine but it sounds horrible. i crank it up in the mornings and it starts to rattle immediately. it sounds as if something is loose in the clutch area and is spinning around with it. it gets quieter as it warms up but it is there always. when driving it is there but you cant really hear it over the engine and everything else from inside.
i can control the noise with the clutch pedal. when pressed in to the floor there is no sound. when released it lets out some sound. however when im letting it out from a stop in gear there is a lot of sound as the clutch gets into the friction zone. this is not the transmission making any noises. if i hold my foot on the brake preventing the car from moving i still get the same sound as i let the clutch out in gear. the trans can not be spinning at this point since my foot is on the brake and the trans is in gear.
nothing has changed from before the noise to now other than the noise appearing. the clutch pedal still feels the same as it has for the 80k miles ive had this car. the car still drives and shifts great. the gripping of the clutch is great. i love the midrange and top end pull of the engine with the AL flywheel. ive put a couple hundred miles on the car since this noise has started.
thursday i pulled the trans and inspected everything. nothing was loose or showing any signs of irregular wear. the release bearing was slopping around against the PP springs, but the retaining spring/ring was still there and it was loose like this when i first did the clutch. the throwout bearing sounded normal and spun freely. the springs in the clutch disc were tight. however this was with the disc simply sitting on the counter. not sure if its possible for it to be distorting once its squished between the PP and flywheel allowing the springs to move freely. so just like the car drives perfectly fine everything looked perfectly fine.
i was thinking i need to replace the throwout bearing, but i don't have any money to simply throw at the car. since it appeared fine when inspected i couldnt justify replacing it without knowing for sure. also i spoke with the head clutch tech at Sachs. based on how the system works he said it cant be the throwout bearing. its under load when im letting the clutch back out. i actually stumped him so badly that he wants me to call him back when i figure out the problem.
on the way home the only thing i could think of is the clutch fork itself. with the slave disconnected the fork is pretty loose even when attatched to the throwout bearing. when the slave is in the trans it should be keeping pressure on the fork. when reinstalling the slave i did have to push it into the trans causing the rod to be pushed back into the slave. so my only thought is that even thought the slave is applying pressure to the fork its not enough and the fork is rattling around in there. this makes no sense to me though considering the pedal feels fine and i would think it would get slack if it was a hydraulic problem.
the car is a 96 formula. ive got a fidanza flywheel and a OEM replacement Sachs clutch. the pilot bearing and throwout bearing was replaced when i did the clutch. the hydraulics are all original with 145k on them. i did the clutch job easily 5k miles ago. this noise just started last week. no other issues other than the noise.
so im all ears as to any suspected causes.
thanks
thanks
