View Full Version : How to repair Chevelle rear suspension
jglover
01-29-2006, 07:54 PM
What's the best way to repair the rear upper suspension mounts on the frame of a 68 chevelle. It looks like someone cut the outside part of the mount with a torch to get the rear out at one time.
Thanks, Jason
https://static1.pt-content.com/images/pt/2006/01/t127630155-1.jpg
Randy67
01-30-2006, 06:15 AM
You could get another A-body frame and either cut the mounts out of it or use it for a template to make new mounts from metal (10 gauge???). They are flat pieces so it shouldn't be hard to make.
rohrt
01-30-2006, 06:28 AM
The frame looks old and rusty. Might be a the perfect reason to track down another one and get it blasted, painted and rebuilt. Replace all the bushings and have a tight ride.
Travis B
01-30-2006, 06:38 AM
I can't really tell a whole lot form that pic it isn't very big?
Derek69SS
01-30-2006, 07:33 AM
Use the other side as a template, and cut it out of a piece of 1/8" steel, then weld it on... maybe add a couple little gussets to be sure it will hold.
Don't throw away an otherwise perfectly-good frame. That rust is no big deal. As long as it's solid right behind the cowl, it's no big deal.
derekf
01-30-2006, 08:38 AM
Or you could take this as a wonderful opportunity to try out one of the other rear suspension options out there - which would probably be where I went from here (3-link, torque arm, etc).
In fact, you might want to get a hold of the folks from Hotrods to Hell - I don't know if they cut these brackets off the frames when they add their truck-arm, but if they do then they've probably got a couple sitting around that they could send.
CAMAROBOY69
01-30-2006, 08:47 AM
Is there a bigger version of that pic?
jglover
01-30-2006, 06:20 PM
There's some larger pictures in my picture trail account. Just click the link in my signature. I was hoping these parts would be available. Because believe it or not this car is in better shape then my Camaro https://static1.pt-content.com/images/noimg.gif There's hardly any rust on the body.
Thanks, Jason
John Monnin
02-26-2006, 05:50 AM
You could just install a full fabricated frame, Swartz Performance is selling a completely fabricated A-body frame for a base price of $2395.
http://www.schwartzperformance.com/
I bet it gets pretty expensive if you start getting options. A full rolling chassis is $11,000 per their webpage
It ljust looks like a really easy way to get a very modified suspension under your A-body
andrewb70
02-26-2006, 06:19 AM
That looks sweet!
1970cuda
02-26-2006, 09:17 AM
that chassis is for a wagon they are building.
http://www.schwartzperformance.com/64wagon.htm
USAZR1
02-26-2006, 03:13 PM
Nice looking frame and 64 wagon. Air Ride,too. Is that a four link?
protour_chevelle
02-26-2006, 06:29 PM
Pays to look at the picture closer lol. Ignore me. :nopity:
-Matt
