View Full Version : c-clip elimiator with disc brake rear?
dougs68ss
01-24-2006, 07:22 PM
im pulling my hair out trying to find a disc brake rear kit to use on my 68 rear 12 bolt, and still have an emergency brake. wilwoods dont. baer im not sure ,they say ther not sure. ive found a really decent priced 12'' from performancebrakes with a manual piston e brake(like baers) any body ran into this? thanks.
Steve68
01-24-2006, 07:41 PM
Yes, I'm getting rid of my Strange C-clip eliminator, and that means a new housing or DTS modifing mine with Ford axle bearings, nothing simple,
navyflyer72
01-24-2006, 08:25 PM
I have a Moser 12 bolt, with c-clip eliminators and the Baer 12 in tour rear discs, they came with rear emer brake (manual) that you can convert to work with your stock e brake cables (with the Baer supplied end cables), or, like me, you can copy the Mule and mount a trans tunnel Lokar e-brake. I have a few pics if you need them, just send me your email.
-George
BBPanel
01-24-2006, 09:45 PM
another possible solution:
http://www.scarebird.com/
at the bottom of the page
capbuster
01-26-2006, 07:30 PM
Call Noel @ Touring Classics. I know he has been working on fitting his kits to Ford rears and he is working on getting my Moser 12-bolt w/ c clip eliminators fitted for his rear kit. May be exactly what you're looking for.
I'll also be using his front kit with my new AFX spindles!
Patrick
01-27-2006, 12:58 PM
I just posted on how I am using Touring Classics on a Ford 9"----No C Clips....I am not sure how to link to it though???
Look under the Brake Section for "Touring Classics on Ford 9".
BMullin
01-27-2006, 03:55 PM
This can be a tough situation to overcome, but we can produce a 12.19" X 22mm kit using Wilwood 4 piston Superlite calipers with the Mr. Parker parking calipers for your 68 with c-clip eliminators. I can get this kit built in about 10 weeks and the price will be 1759.00 of which 600.00 down will be required to start and the remaining balance due upon shipment. If you have any questions please contact me. Thanks
Billy
Steve68
01-27-2006, 05:28 PM
Billy, I don't know which on of us your directing this too, but thanks for the info, I'm personally going to use a either a 12 bolt housing new or used, I have a 12 bolt under my 70 Nova,
zo66
01-27-2006, 08:17 PM
hi i am in the same boat,i found a guy on e bay that had a kit that had a bracket that you had to weld in place to make it happen i think it was rodpartsdealer but i am not sure.i decided because i live in fla just to do with out and bought areo space components for the rears,very nice for the price.good luck
dougs68ss
01-28-2006, 10:16 PM
baer makes rear disc kit for elimator c-clip rear end with pb provision (single piston manual caliper) price is reasonable,iguess 2000$ front and rear.13''discs all hard wear included...ps i found this set up the best way to go on my 12 bolt rear. some guy in washington had asystem but it was to expensive and too long to build...
