View Full Version : gen7 question
emtcee1973
01-24-2006, 05:10 PM
to start off motor is a chevy 383...i have a gen7 steup(calmap v4) and i am trying to tune the ve table...my question is when i run a datalog and i go back to review it,there are some points on the log i can't seem to tune..for example, when vacum is say 9psi i can't seem to take any more fuel out of the ve table...i already have it as low as it will go(.100)and its still real rich..the ve table only goes as low as 13.44..i tried to adjust it to read lower but calmap tells me that the value is out of range and it also says i can't scale the first value in the map axis...is there another table that can be adjusted to solve the problem??i would appreciate any feedback...
thanks,mike
ps..injectors are 30lb/hr
nitrorocket
01-24-2006, 07:04 PM
I assume you have a wideband. You need to set up your commanded afr table first. Then tune the ve table. The computer is automatically adding more or less fuel when in closed loop. Start with 13.5-14.7 accross the board, in the last 3 columns of the afr table, taper it down to about 12:1 and start from there. Hope this gets you started!
emtcee1973
01-25-2006, 06:34 AM
thats how i did it...i set up the a:f table just like you suggested..and yes i do have a wideband...but like i said, its way rich beyond where i can adjust it on the ve table...any other suggestions???thanks for your help..
mike
camcojb
01-25-2006, 08:46 AM
Do you have the injector size, etc. in config correctly? What fuel pressure are you running?
Jody
emtcee1973
01-25-2006, 09:16 AM
yeah all of that is correct...fuel pressure is set at 42lbs...
mike
nitrorocket
01-25-2006, 03:24 PM
What is you afr at idle. Those are tiny injectors, you should not have a problem. In closed loop at idle, how many percent of fuel is it adding or subtracting?
emtcee1973
01-25-2006, 05:28 PM
afr at idle is 15.1.....its only correcting around 2-4%, which is where i want it....anyway i think i figured out my problem....thanks for all of the help guys....
