71rs
01-22-2006, 08:41 PM
I've got a 71 which I'm running a 16x8 4.5" BS wheel (vintage wheel works V45) and 255-50-16 all the way around (Toyo RA1's). No rubbing and everything is pretty much ok so far. The rears are a perfect fit, the fronts are a tiny bit offset to the outside more than I'd like, in terms of looks.
This post is about the scrub radius though - I think geometry-wise, I have the front wheels too far out. there was a noticable difference from my old 15x7 stock setup, in terms of a rough roads' ability to kind of grab the car i.e. hitting a moderate pothole with RF tends to "steer" car to the right. The old 15x7 with BFG radials didn't seem to do this. Suspension is rebuilt so it's not old bushings or anything like that.
I've reset the front suspension to around 4* caster / -0.5* camber (max caster I could get with the stock A-arms with just about no shims in the front and a fairly thick stack of shims in the rear). This has helped a decent amount (and was a great benefit to overall steering feel), but has not eliminated the problem.
I've done some searching and looking, but I haven't been able to find a real solution to this problem (outside of going to 17" wheels with more backspacing). It seems like what I need is a spindle that brings the entire wheel assembly closer to the spindle by about half an inch or so. The complications are that, if the wheel assembly is half an inch more in, I think it would hit the stock steering tierod end and possibly the A-arms as well. So I'd need this imaginary spindle to also push the outer tierod end hole towards the center of the car a 1/2" or so (and the obligatory tubular A-arms).
I have no idea what either of these suspension changes would do to my geometry. I don't think moving the wheel in would affect anything (other than to reduces reduce scrub radius), but no idea what the tie-rod end move would do to my bump steer/ackerman etc.
I know that 17's would give me more clearance and solve the problem, but I rather like the look of these 16's and the toyo ra1's in 255-50-16.
So, I'm wondering if anyone knows of any options to improve upon the situation or has any ideas?
Attached a few pictures, quality is not so good and I'm sure we all know what it's like to have a car in the "project" stage. :)
