69Myway
09-27-2004, 04:27 PM
I was told this could not be done, but a friend of mine gave me a junk 1988 Caprice tank (with intank pump). I slid it under the Camaro. Obviously the plus is extra fuel capacity, a proper in tank sump location for slosh, and the ability to drop in a stock high pressure MPI pump.
So, here is the initial result. It fits just fine between the springs. I cut the neck for test fitting. It would requre a new one to be soldered on there.
In these pics it hangs down a tad low as the pick up in the top is raised. "IF" I run this style tank I would notch my truck floor for two reasons:
1. Proper tight fitment of tank against the trunk floor
2. Easy access to the pump for service as needed.
What do you think?
https://static1.pt-content.com/images/pt/2004/09/tank_test_fit_1JPG-1.jpg
https://static1.pt-content.com/images/pt/2004/09/tank_test_fit_2JPG-1.jpg
https://static1.pt-content.com/images/pt/2004/09/tank_test_fit_4JPG-1.jpg
https://static1.pt-content.com/images/pt/2004/09/tank_test_fit_3JPG-1.jpg
What do you think?
