View Full Version : Ridetech Tru-Turn for Second Gen brake options
Rsj4h
04-10-2026, 04:19 PM
Hi all,
I have a Tru-turn kit for my 78 Trans Am that I'm going to be installing and trying to figure out what rotors or brake kit I need to get for it. It uses the 67-69 Camaro 2" drop tall pin spindles.
79 Camaro
04-11-2026, 12:57 PM
Contact Ride Tech for advice?
Josh@Ridetech
04-21-2026, 07:12 AM
Hi all,
If you have our older kit that uses the 1st gen spindle, you would use any kit set up for the standard disc spindle pin. Wilwood, Baer, etc.
We stock the Wilwood here but can sell you the Baer stuff as well if you want to go that route (typically takes a couple weeks).
Wilwood option: https://ridetech.com/product/front-wilwood-dynapro-6-brake-system/
Baer: https://ridetech.com/product/baer-brakes-pro-tall-spindle/
Or if you want to go more economic, you could go to any parts store and get replacement rotors, bearings, and calipers for a stock 67-69 Camaro/Firebird. You just need to get the caliper brackets to bolt onto the spindle. Example: https://www.camarocentral.com/1969_Camaro_Front_Disc_Brake_Caliper_Brackets_p/brc-181.htm?srsltid=AfmBOorfLzOycZJ03Ux-czRnzLq6MJ2MjpSXj9yU5hzxbo-yviUKE8CLCmY
