View Full Version : OEM ECU Control vs Standalone for ZF 8HP — Real-World Experience?
BruiserConversions
04-07-2026, 06:25 AM
We’re currently developing and refining a full OEM-controlled ZF 8HP swap solution for LS/LT and Gen 3 Hemi platforms.
Instead of using a standalone TCM or CAN bridge, we’re controlling the transmission directly through the Chrysler GPEC2A ECU with native CAN integration.
Goal is to retain:
OEM torque management during shifts
Proper shift scheduling & clutch control
Adaptive learning behavior
Consistent drivability across all conditions
For those who’ve worked with or driven 8HP swaps:
Where do you see standalone systems falling short (if at all)?
Has anyone experienced long-term drivability issues or inconsistencies?
How critical is OEM-style integration vs just “making it shift”?
Would love input from anyone who’s tuned or daily-driven these setups.
dontlifttoshift
04-08-2026, 04:47 AM
Before we get into all of that, what ECU are you controlling the engine with and how does that integrate to the GPEC2A?
BruiserConversions
04-09-2026, 02:51 AM
Good question — and this is really where our approach differs from most of what’s out there.
In our setup, everything is actually controlled through the GPEC2A — both engine and transmission. We’re not running a separate GM ECU alongside it.
The goal from the start was to keep the entire system operating under a single OEM control strategy rather than trying to make multiple ECUs work together through CAN translation or standalone controllers. That’s where a lot of the common issues come from.
By keeping everything on the GPEC2A, we’re able to maintain proper torque management, shift behavior, and overall drivability the way the transmission was designed to operate.
I’ll keep the specifics a bit high-level, but the focus has been making the engine and transmission behave as a complete, native system — not a combination of separate controllers trying to cooperate.
That’s really been the difference for us in getting consistent results across different platforms.
Follow us on
YouTube: 8hpswaps
Instagram: Bruiser Conversions
where we discuss this a little further and will continue to post more about how it all works.
dhutton
04-09-2026, 04:34 AM
So you are using a Chrysler ECM on GM LS and LT engines? Would you use HPT for tuning?
That would be pretty cool. The 8HP solutions I have seen are a bit of a kludge and expensive. Hopefully you will have a better price point.
dontlifttoshift
04-09-2026, 04:57 AM
This, I like
But I am not your target audience as I have zero interest in a GM engine controlled by another manufacturers OEM ECU. Tuning GEN V stuff is hard enough with E92s. I absolutely want OEM drivability but am unwilling to give up the complete, adaptable, and relatively easy control that I get with a stand alone ECU/TCU combination.
dhutton
04-09-2026, 05:32 AM
This, I like
Hi Donny. Unrelated but have you used Holley control of a GEN V?
BruiserConversions
04-09-2026, 06:19 AM
Yeah — we’ve been running Chrysler GPEC2A control on GM LS/LT platforms for a while now. Early on, a lot of that was done alongside the GM side (E38-based setups), and we’ve been refining that approach for just over 8 years in real-world applications.
More recently, we’ve developed a cleaner solution for GM platforms that no longer requires the GM ECU at all — everything is handled through the GPEC2A. That’s really been the key to getting the ZF 8HP to behave the way it was intended from the factory, especially when it comes to adaptability and overall drivability.
As far as tuning goes — yes, you can absolutely use HP Tuners. That’s been an important part of keeping things accessible from a calibration standpoint.
And I hear you on the current 8HP options — that’s exactly what pushed us down this path. The goal was to simplify the system, improve how it actually drives, and make it more practical overall — not just something that works on paper.
dontlifttoshift
04-09-2026, 06:24 AM
No sir, but Andrew has. They just use an external module for the direct injectors, like nearly everyone else in the aftermarket. After that it's the same as any other Holley application.
Which brings up an interesting question for the OP. Is the GPEC2A capable of driving the direct injection in a LT engine or are you converting them to port injection?
BruiserConversions
04-09-2026, 06:48 AM
Totally get that — standalone definitely has its place.
What we’ve found though is the 8HP’s real advantage is its factory adaptability, and that only fully comes through when it’s run on GPEC2A.
All the OEM learning, shift behavior, and torque management is already built in — that’s what makes it feel right.
So it really just comes down to priorities:
max control vs. true OEM behavior.
BruiserConversions
04-09-2026, 06:58 AM
Good question — in our setups we convert the LT platforms over to full port injection.
Once you start pushing those engines past ~700hp, the limitations of DI become pretty apparent from a fueling standpoint. You end up needing to supplement it anyway, and at that point you’re running two systems on the same engine.
We’ve found it’s cleaner and more consistent to just go full port injection and build the system around that from the start. It simplifies control, makes scaling power more straightforward, and avoids stacking complexity.
We’ve consistently built LT4 setups in the 1,000–1,100hp range using port injection with everything controlled through the GPEC2A, and it’s proven to be a solid combination.
I don't trust this because you use AI to make you posts
dhutton
04-09-2026, 09:40 AM
? Their website and Instagram look legit.
BruiserConversions
04-09-2026, 11:09 AM
just using AI to articulate clearly and grammatically
BruiserConversions
04-09-2026, 11:18 AM
we are legit been doing business with 8hp swaps for over 8 years. our company is Bruiser Conversions (bruiserconversions.com), instagram: Bruiser conversions.
Just trying to gauge if this is something people are actually looking for and want, as well as get real feedback. We've dealt with almost every aftermarket device out there for 8hp and sound German by far has been the best. But it is just another workaround, this is what lead us to developing a system that is only reliant on 1 native system being the GPEC2A, allowing the 8hp work as it was meant to with its adaptive capabilities learning throttle input and shift strategies, and just everyday drivability. not just a swap that is good at WOT.
Vimes
04-09-2026, 04:34 PM
The Dodge computer is actually pretty nice as is. On the LS vehicles I've had I have always messed with the programming to get them to run the way I wanted, but have now had two Dodges with the 8HP and have felt no need to get into the computer. They just run the way I want them to from the factory. I just wish they weren't such heavy pigs as my Charger was right at 4300lbs and my Durango is something like 5300lbs.
If you had posted this last year, it sounds like I would have been a customer. I really wanted an 8HP behind a nice, lightweight LS, but didn't want to get into the whole multiple computer systems having to adapt to each other mess. I've since invested in a Gen 3 392 with an 8HP behind it as I got a pretty good deal on a low mie takeout from a 2018 Challenger. Good luck with it.
BruiserConversions
04-10-2026, 03:52 AM
you nailed one of the biggest reasons people like the Dodge setup.
The factory Chrysler calibration with the 8HP is just right out of the box. The shift strategy, torque management, part-throttle behavior, it all works together the way it’s supposed to, which is why most people don’t feel the need to mess with it like they do on other platforms.
That’s actually the side of things we focus on with the HEMI setups. Instead of trying to reinvent anything, we lean into what already works, keeping the factory ECU and control strategy intact so the 8HP behaves exactly like it does in a stock application, just in a different platform. It really comes down to preserving that OEM drivability rather than trying to tune around it.
And that 392/8HP combo you picked up is hard to beat, especially with a clean takeout. That’s a great foundation, and like you said, it takes a lot of the guesswork out of the equation.
Appreciate the feedback!
jaybee
04-11-2026, 11:47 AM
I've studied up some on 8hp swaps. It seems like an incredible transmission, but the available transmission controllers are extremely expensive.
BruiserConversions
04-14-2026, 04:26 AM
That’s honestly been one of the biggest barriers, by the time you price in a standalone controller, harness, and everything else, the transmission itself almost becomes the cheap part of the swap.
Makes me wonder, what would the market actually value a system at if it eliminated the standalone completely?
If you could run an 8HP off the factory ECU with full OEM behavior, no extra controllers, no added complexity, what would that be worth to you?
dontlifttoshift
04-14-2026, 04:29 AM
Aside from converting to port injection, what other engine modifications are required to run this ECU?
dhutton
04-14-2026, 05:01 AM
I would be willing to pay around the price of a Speartech harness and ECM. Much more than that and I’m a hard pass.
BruiserConversions
04-14-2026, 07:18 AM
There's a good bit that we do on the LS/LT aside from just port injection to operate on our fully integrated harness. We offer complete packages for LS/LT 8hp swaps meaning engine and transmission together, for a plug and play conversion. On the Hemi side we are able to offer just a harness package that allows anyone with a gen3 application to easily swap in an 8hp with our harness kit.
BruiserConversions
04-14-2026, 07:24 AM
I don't believe speartech offers a harness fro 8hp swaps, so if were talking swapping in an 8hp then it would require the correct harness as well as a standalone unit to isolate the 8hp transmission communication, which adds up quick. Which is why we have developed a solution to eliminate the need for added external devices.
dhutton
04-14-2026, 07:35 AM
Understood. I’m simply saying that’s as much as I would spend for any harness ECM package. Their prices are premium and it’s a hard stop for me.
Cost is why I’ve not done any 8HP swaps. If you can’t lower the price significantly I’m still not going to do any regardless of performance or elegance of the solution.
dhutton
04-14-2026, 07:48 AM
$35k…. I’m not one of your target customers at that point… :)
dontlifttoshift
04-14-2026, 10:09 AM
I really don't think it is a complicated question.
BruiserConversions
04-14-2026, 10:29 AM
You’re right it’s not a complicated question.
The simple answer is our system works, and we’ve proven it through actual running builds. Not a concept, not a bench test, real vehicles, real results.
Everything else is just details behind the curtain.
give us a call and we can chat more about it. 727-317-4902
BruiserConversions
04-14-2026, 10:33 AM
I completely get that and I appreciate you being upfront about it.
That kind of pricing would definitely narrow the audience quite a bit. Our goal is to deliver something that justifies its value through how it performs and integrates, but we also understand it has to make sense for the customer and the build.
dontlifttoshift
04-14-2026, 12:58 PM
The simple answer is, "we also need to do _____ to the engine to accommodate this ecu"
Vimes
04-14-2026, 06:06 PM
To answer the mods required question it's understandable you don't want to give away secrets, but it does need to be answered. Does it need a Dodge temp sender? Does it require drilling holes in the block or adding sensors? Can it use the Chevy engine's reluctor wheel? Or is the harness already set up to plug into the Chevy engine as-is and the computer already set up to know what it's looking at? Sure, there might be one or two guys who will take what you say and try to make their own, but the great majority of us will say "Hey, look, just what I need, a solution in a box that will save me a ton of time" and buy your harness. Stating what extra work is required is just giving people an idea of how much work is involved with making the swap.
Price-wise, I agree that it would need to be in the range of other standalone harnesses, like the Holley or Speartech stuff. Make it too much and people will simply elect to go with a Holley which can run a 6L90E. As much as I love the 8HP transmission, I was looking hard at the 6 speed solution because the 8 speed/LS was getting overly complicated, pricey and dependent upon too many different small companies for electronics. I'm planning to drive my project to the graveyard, so I have to have a mind towards the future. I can fix a wiring harness 10 years down the road, but can't replace someone's one-off computer after they go out of business.
Oh, and are you only doing LT engines or are you also doing Gen3/4 LS engines? There's still millions of LS engines out there.
dhutton
04-15-2026, 03:40 AM
Did you remove your standalone harness etc from your website? I know I saw it but now I can’t find it.
srode
04-15-2026, 04:24 AM
its a great concept, but I think your client potential is definitely going to be limited without more information on mods needed to make it work. People building these cars are gear heads for the most part and want to understand their build details to make design choices, thats what gear heads do. My interest was gone with using port injection vs direct but more details like that help people sort power train options.
BruiserConversions
04-15-2026, 04:48 AM
I get where you’re coming from, that’s a valid concern, especially when you’re trying to understand the scope of what’s actually involved.
At this point in development, running an LS/LT platform solely on the GPEC2A with full 8HP control does require a fair amount of restructuring on the engine side. That includes aligning sensor strategy, crank/cam signal interpretation, and overall input mapping so the ECU can properly manage both engine and transmission in a true OEM-style torque-based control system.
Because of that, it’s not currently a “drop-in harness” solution where you can just plug into a stock GM configuration and go. There are changes required to make the engine package fully compatible with how the GPEC2A expects to see and control the system.
That’s the reason we’re only offering it right now as a complete engine/transmission/harness package on the GM side, it allows us to control all variables, ensure proper CAN communication, torque modeling, and shift strategy, and ultimately deliver consistent results without relying on the end user to bridge those gaps.
We are very close to having a solution that brings it more in line with our HEMI offering, where it becomes a true standalone harness kit that interfaces cleanly with LS/LT platforms in a plug-and-play format, but it’s not quite at that stage yet.
So as it sits today, if someone wants to run an LS/LT with an 8HP on the GPEC2A using our system, it does require the full package to make everything operate correctly.
And yes, we’re actively working across both LS and LT platforms. We’re well aware of the volume and long-term viability of those engines, so that’s a major focus for us.
If you have more questions give us a call happy to answer any questions. 727-317-4902
ryeguy2006a
04-15-2026, 04:49 AM
Looks like based off of a quick google search, the 09+ Gen3 Hemi's use a 58x crank and 4x cam sensor for their spark control. So you should assume that you'd need to run all the other Hemi sensors on the engine as well as the Throttlebody and MAF (if they have one). Essentially you're tricking the ECU to think it's running a Hemi engine. Maybe lucky if one of the sensors is a direct replacement, but unlikely.
But like Vimes said, this would probably apply for the guys that are starting projects from scratch with no existing harnesses. Someone like myself who's already invested in my Holley ECU won't want to straight up switch to another pricey harness. In my case, I'd go with the TurboLamik that can talk with Holley and go on my way. Or if Holley can launch their own controller that can integrate with Terminator X which would be incredibly cool.
The other components are the adapters needed to physically bolt the transmission which are very pricey as well.
BruiserConversions
04-15-2026, 07:09 AM
understood, the plug and play harness for GM will be a much more attainable price point and build friendly for various LS/LT applications. all said in done our goal is to be able to save builders and enthusiasts time and money in their 8hp swaps and offer an alternative to having to run a standalone and parasitic device. For race applications it they definitely have their place don't get me wrong, but from my experience having something your everyday driver can use on the street that operates as factory with the ability to take to the track is a win/win in our book.
I really appreciate all the feedback
