View Full Version : 69 Camaro DSE 4 pt Cage
balchz06
09-07-2025, 05:17 AM
Thought I'd share the 3D printed covers I made for the roll cage as it goes thru the package tray - this is a 69 Camaro project I'm currently working on. They're slightly larger than the tubing and slip into place before the cage goes in.
218378
dhutton
09-07-2025, 05:47 AM
Those are nice!
Olds.PhD
09-07-2025, 06:26 AM
So, these look great, but something to consider before finalizing it: what material are you using and is it UV resistant? That area is going to see a lot of sunlight and certain plastics will not do well in that application. You could paint them, but as the paint breaks down, that area will be a royal pain to try to repaint without removing glass.
hp jnkey
09-07-2025, 08:28 AM
would be cool if these were split down the middle allowing installation or removal after the bar is installed.
Maybe a ship lap joint you could glue together or something like that
balchz06
09-07-2025, 11:18 AM
It's a high temp UV resistant resin - I don't have the resin spec handy, did it at work. But, I thought about that and if it fails over time I'll cut it off and design another one that is split. The car doesn't see a lot of sun by any means, I guess time will tell.
XLexusTech
09-07-2025, 05:10 PM
Nice work . !
balchz06
09-07-2025, 05:18 PM
Here's how they turned out, installed the cage today.
218383
balchz06
09-07-2025, 05:20 PM
Thanks...appreciate that!
badbu68
09-08-2025, 10:40 AM
Yes, next step would be to create a 2 part snap together and then the following step is to offer it covered in alcantara. Just kidding, they look great!
balchz06
09-08-2025, 05:02 PM
Hey....thanks. Actually, I've been working on that split part design that would glue together. Might be a while before it's done, I'll follow back up with some pics when I have something.
