View Full Version : electric fuel pump
68-vert
08-30-2025, 07:50 AM
I think my electric fuel pump has failed.
1-I don't hear the pump when I turn the key on.
2- The fuse is not blown.
3- My Optima trunk mounted battery has 12.43 volts.
4- I don't see fuel entering the FIT throttle body.
What am I missing ? Is there something else I need to check ?
dhutton
08-30-2025, 08:23 AM
Measure the voltage at the pump when you turn the key on. Sounds like you have EFI so it could be ECM or fuel pump relay etc
68-vert
09-01-2025, 08:14 AM
Thank you, I'll let you know what I find. After 10 years this is the first issue I've had so I'm lucky I guess.
