View Full Version : 1970 Chevelle Malibu - LS Turbo T56 magnum 6 speed 12 bolt 600hp
bochnak
08-07-2025, 05:51 AM
Asking: $32,000obo no trades
VIN: 136370L200654
5.3 turbo with T56 magnum built for up to 600rwhp+. Runs on E85 or pump, flex fuel. Currently tuned conservatively at around 450rwhp (9-10psi). Runs and drives great, handles really well, drive/enjoy it anywhere now. About 2-3k miles on new/rebuilt/swapped drivetrain. Been driving as is for the past 3 years. Many parts to complete come with sale. Mostly solid body, car spent life in California/Nevada until 2005 when shipped it to Chicago area. Have owned car since 2005. This is a malibu trim car.
More pics:
https://photos.app.goo.gl/D87358VvorsCkikQA (https://photos.app.goo.gl/D87358VvorsCkikQA)
Video cruising & boost hits:
https://youtu.be/oncgYfy7ecA (https://youtu.be/oncgYfy7ecA)
Walkaround video:
https://youtu.be/56QFBD2uJcM (https://youtu.be/56QFBD2uJcM)
Over 70+ videos on youtube on this build:
https://www.youtube.com/playlist?list=PL82YKl1Zk5elAuG1lp4g5G2H9DA4sjjQj (https://www.youtube.com/playlist?list=PL82YKl1Zk5elAuG1lp4g5G2H9DA4sjjQj)
Ls swap parts used:
Holley 302-3 oil pan
Holley forward engine mounts
Holley trans x member
Engine:
2005 gen 3 5.3 truck motor, with gen 4 internals. Fresh rebuild (about 300mi) with gapped rings and LS9 small bore head gaskets. Heads were redone/valve job.
Elgin E1840P Sloppy stage 2 cam
Pac 1218 valve springs
VS 7875 turbo
VS 44mm wastegate
VS blowoff valve
Griffin radiator
Windstar electric fans
PWM fan controller standalone
Holley terminator X ECU
Flex fuel harness
AEM dial a boost - not installed
Viair onboard air compressor - not installed
Dual mac valves/dome sensor for boost control - partially installed
Bowler t56 harness
Fuel system:
Rick’s restomod efi tank with corner pickups
CTSV dual fuel pump module with AEM upgraded pumps
Vaporworks fuel pump controller
Returnless system
Boostworx system wired up not activated (boost reference FP increase)
This is a PWM system
-6 from tank to rail
Flex sensor wired up and tuned for pump gas or ethanol
80# injectors
No fuel starvation down to 1 gallon
Drivetrain:
T56 magnum 6 speed transmission - about 2k miles
Monster twin disc clutch
Tick upgraded master
Denny’s nitrous ready driveshaft 3”
Sonax 1350 slip yoke
Rear end:
Built 12 bolt rear end - about 3k miles
Ford 9” ends
Moser 35 spline axles
3.73 gears
Eaton posi
TA cover
Welded tubes
1350 pinion yoke
Powdercoated housing
Suspension:
600# front springs
175# rear springs
1” front sway bar
No rear sway bar
Front upper SPC adjustable control arms
Tall ball joints to improve geometry, 1” total
Stock boxed rear lower control arms
UMI adjustable rear uppers
Varishock single adj front shocks
Ridetech single adj rear shocks
All bushings replaced
Quick ratio steering box
Modern alignment - ⅛” toe in, -0.5° camber, +5-6° caster
Brakes:
C5 corvette brakes 13”F/12”R
SS lines to calipers
Provisions for parking brake - currently no parking brake
Hydroboost brake booster
Brakes work extremely well
Wheels/tires:
C6 corvette wheels
Front tires - 245/40R18 Firestone Firehawk Indy 500 - MFG date 2019
Rear tires - Atturo AZ850 UHP 305/30R19 - MFG date 2023
Tires have 80-90% tread on them
Exhaust:
Fahler speed performance SS cast turbo manifold passenger side
F body driver side manifold
2.25” crossover
3” downpipe
Pypes 3” full exhaust all the way to bumper - 409SS
Large dynomax mufflers (2)
Vbands everywhere
Body:
Very mostly solid body
Has original quarters
Was vinyl top car - roof has rust under paint
Rear window channels have rust and will leak
Solid floors and trunk
Paint is a 20’ footer/driver quality
New body bushings and bolts
Color is Mopar F8
Electrical:
Delphi/Aptiv/GEP waterproof fuse and relay box under hood (iso 280). Tons of room for expansion if needed.
Extra prewired circuits if needed in future.
Hella E code headlights. H4/H1 with relays.
Wiring is engine bay is complete
Interior:
Buckets seats
I have the insulation and carpet
Needs a new headliner
I have the dash pad and all interior parts
I have the manual trans console plate
Air conditioning
Factory A/C car. No A/C at the moment. Build planned for vintage air etc. the compressor will fit in stock 5.3 truck location. 30A relay prewired for A/C when ready. Fan controller A/C ready.
Work that needs to completed:
Wiring and mount ECU
Heat exchanger for intercooler comes with sale, will need to be fabbed and installed. Water tank need more fab work. Bosch water pump installed.
Heater hoses need to be hooked up for heat to work.
Speedo does not work. Trans harness has 2 outputs for digital speedo.
Regarding the rust on roof, this can be repaired and vinyl top installed without having to repaint the whole car.
I have many parts that come with sale. All fluids have been changed and the car is ready to drive anywhere. I wouldn’t hesitate to take it on a long trip. It has great street manners and doesn’t complain too much cruising as low as 1400rpm in 6th. No leaks anywhere except a small seep at the rear axle retainer. Car is pretty fuel efficient if you can keep your foot out of it. Overall a very solid car that is a blast to drive when the boost kicks in. Puts a smile on my face every time and shocks all new passengers!
218046
218047
218048
