View Full Version : Switching from Dakota Digital to Speed Hut
rushca01
07-23-2025, 09:51 AM
Need some help guidance on switching my Dakota digital gauges to Speed Hut gauges. I’m using a Holley terminator x ECU and trying to determine what i need for the ecu to talk to the gauges.
130fe
07-26-2025, 05:04 AM
Probably going to have to run the Speedhut senders. I don’t believe there is a “BIM” module for the speedhut stuff.
Vimes
07-26-2025, 11:47 AM
I've never used or talked to them, but you might look at these guys.
https://shop.classicinstruments.com/zeus-link-obdii-module?__cf_chl_f_tk=ViUkTIhqYeAkluqoaRLFYgpidiV28 G3VrP49_7etvx0-1753559164-1.0.1.1-UR6gY7fy75UpmNwZae9oCAdszZu_L3ZEf.8FITMLjg4
It looks like Holley likes them though, because Holley bought them.
https://www.holley.com/blog/post/classic_instruments_zeus_link_simplifies_ls_gauge_ installation/
ztk123
07-26-2025, 12:53 PM
I used the speedhut gauges with GMPP ecu and harness. They plug in to a OBDII port or Canbus signal. You may check with Holley about compatibility, if I remember correctly they want you to use Holley’s version of gauges.
- - - Updated - - -
cdrod
07-27-2025, 07:01 AM
I chose SpeedHut gauges for my 442 convertible project, but I still have the '72 Olds engine so I used the analog senders not OBDII or Canbus. SpeedHut sells speedos in Canbus/GPS/VSS versions and tachs in coil/Canbus versions. My goal was accurate gauges, and add a volt gauge but I also wanted to retain the original look. SpeedHut allowed me to customize the gauge faces to resemble the factory gauges. Here's some pics
Rodney
217809
These are the oversized 4-1/2" diameter gauges. For a small design fee, SpeedHut allowed me to customize the ticking to fit within the stock bezel.
217810
This is the final result. You can choose from about 30 different day/night color combinations. I chose blue because it more closely matched the Olds dash lighting.
Hotwire
07-31-2025, 04:20 AM
Don't go basing your purchases on what Holley "likes". They were bought out by a private equity firm and are on the hunt for making money, not making people happy.
https://www.goapr.com/blog/post/sentinel_capital_partners_acquires_holley_performa nce_products/
Vimes
08-02-2025, 02:24 PM
No worries, I based it on the OP looking for something that will work with his Holley ECU.
