View Full Version : FS: 1967 Chevy C10 Whipple Supercharged T56 No Limit Chassis Components
Parms22
02-18-2025, 09:02 PM
Hey Guys,
Up for sale we have a 1967 Chevrolet C10 Full Custom Pro Touring Build. The exterior of this C10 was painted GM White Black with 3 shades of base, then added with 4 layers of clear coat. The truck is in incredible shape. The car has some of the industry's best products installed on the truck. The Truck has many aftermarket accessories that were installed on the Truck. The Truck has been built with all the best performance and functional parts available on the market. The car has had all the accessories professionally installed. I did tons of research and put the best parts into this car and it sure did pay off. The performance of the car is incredible, and the ride quality is superior. The Truck has served me very well and has very low miles as I have many other cars. The exterior of the car looks great. Those that have built a Pro Touring Truck know about all the issues that you face. Well I have addressed all those concerns, and this is a turnkey car that only needs regular maintenance. The interior is also all Brand New and in excellent condition. The truck gets looks wherever it goes. The truck is free and clear with nothing owing. Below I will go over the list of additions and modifications that are on the truck. The truck went through an extensive restoration and below I will go over some of the modifications that were done to the car. If you have any questions, please call or text me 604-825-5506 and the vehicle is free and clear. Here is a list:
I have over 160k into this truck and have all the receipts to prove it. ASKING 95k USD
Video links
https://youtu.be/hlSF1Pj4md0?si=dcx7r13A-sxEn8PK
https://youtu.be/_ZeuRzMW5x8?si=Deg6CMse83k9RM2f
https://youtu.be/5ietKivuIbM?si=bd136JjRYaAgNiZV
https://youtu.be/NHSdB_Kw09k?si=cp2ZcTJkNBK5n2tW
https://youtu.be/_ZeuRzMW5x8?si=Un-XBmYxwfv-AGKi
https://youtube.com/shorts/8nwGztJcDbU?si=BJhAk3i8E8PNR_mx
https://youtube.com/shorts/lLen4VtWvjI?si=Adkvf-xctMV6vr07
https://youtube.com/shorts/mR3u8vL5Zg4?si=UeJW_PELrkNosMx0
https://youtube.com/shorts/OkzktznGJhA?si=-WhWjs_BZjcaOG8O
1967 Chevy C10 build
Motor and Transmission
-Fully Built LS2 Engine W/ Whipple Supercharger
-Holly Engine Management system with Screen
-Resurfaced to Match Pistons
-Performance Honed with Torque Plates
-New Durabond Cam Bearings Installed
-Line Honed, Build Oil Clearances In
-Mahle Forged pistons with Anti-Friction Coating
-Clevite A Main and Rod Bearings
-Johnson OE Hydraulic Roller
-HodRod Holley Low Mount Oil Pan
-GM Timing Cover
-GM Rear Cover
-GM Lifter Valley Cover
-Motion Works Billet Valve Covers
-Aeromotive Fuel Rails
-ARP Damper Bolts
-ARP Bolts Throughout
-ICT Billet Full Serpentine kit (Anodized Black)
-New GM factory Crankshaft 3.622” stroke
-58x Reluctor Wheel
-Internally Balanced Front and Rear
-Scat 4340 Forged Steel I-Beam Rods 6.100” Length
-Mahle Plasma Moly
-Cloyes Billet Roller with Hex Adjust
-Melling Select Performance High Volume
-GM Pick Up Tube
-GM Windage Tray
-GM MLS Head Gaskets
-GM Cover Gaskets Aftermarket LS Aluminum
-Three angle performance valve job
-Rev Stainless Steel 2.16
-92mm Billet Throttle Body
-BTR Double Valve Spring
-Light Weight Titanium Retainers and Hardened Locks
-NGK Spark Plugs
-Whipple 6.0 2.3L Fully Supercharger kit
-The kit includes everything necessary to install the kit including: SC, Intercooler system, Fuel Pump Booster, SC Belt System, Spark Plugs, Calibration.
-Motion Works Billet Catch Can
-No Limit Engineering Billet motor mounts
Transmission
T56
-Level Two Tick Performance
-Upgraded Rebuild includes the following:
-Complete tear down, degrease & thorough inspection of entire transmission
-Macleod Short Shifter
-Monster Clutch
-Bronze 1-4 Fork Pads
-Bronze 5-6 & Reverse Fork Pads
-Bronze Shifter Cup Bushing
-Billet 3-4 Synchronizer Keys (with upgraded springs)
-New OEM 1-2, 5-6 & Reverse Keys & Springs
-Carbon Fiber Synchronizer (blocker) Rings
-New Front Seal
-New Rear Seal
-Our Custom 30 Spline G-Force 9310 Alloy Mainshaft
-Upgraded output shaft bushing
-Upgraded output shaft seal
-30 spline slip yoke
-Modified Speed Reluctor
-Cryogenic Treatment of All Transmission Internals
-REM Polishing of All Necessary Transmission Internals
-End-play set to our custom specifications
Paint
-GM Olympic White
-3 layers of base color
-4 Layers of high gloss Clear
-The paint was wet sanded and ceramic coated.
Cooling
-Cold Case Aluminium Radiator with Dual Fans.
-High Flow Heat Exchanger
Body-
-Gibson Stainless Steel Headers 3 inch Collectors
-Brand New exhaust 3 inch pipe with Magnaflow Mufflers and Vibrant resonators
-3.5 Chrome Moly driveshaft SFI Strange slip yoke
-Rick's Stainless steel Pro Touring Tank
-Ricks Tanks straps
-Aeromotive a1000 flow fuel pump
-New Left and Rid AMD Fenders
-New AMD Hood
-New AMD Drivers and Passenger side doors
-New Rear Chrome Bumper Painted White
-New AMD Front Wider Wheel Liners Linex Black
-New AMD Front Rad Support Linex Black
-New Complete Floor Linex Black
-New Inner rockers
-New Front window moulding
-New Rear window Chrome Moulding Painted White
-New Internal Dash
-New Outer Rockers
-New Front C10 Grill with Inserts and window doors with actuators
-New Front windshield
-New Rear window
-New driver and passenger front and rear windows
-Chevrolet Letters on Tailgate
Interior
-Front TMI Interior Sport X Bench seat
-Front TMI Sport X Dash Pad
-Lokar Gas and Brake Pedal
-Bowler 12inch Billet Shifter and Knob
-Atomic Armindillio door panels black powder coat
-Door seals and window seals
-Eddie Motorsports door handles, springs and locks
-Motion Works Billet Fire extinguisher mount
-MPI Steering wheel
-Ididit Full tilt Steering Column
-New front Seat foam
-Kilmat on Floors
-Front Black carpet loom
-New Rear Tail lights
-New glove compartment with hinges
Brakes
-Wilwood Pro Spindle Kit-Spindles, Uni Bearings, Steering Arms, Ball Joints, Bolt Kit
- Wilwood Master cylinder and booster- anodized black
- Wilwood Forged Big Brake Front Brake Kit 6 piston
- Wilwood Forged Big Brake Kit Rear
- Wilwood 12.19 inch Rotors Front
- Wilwood 12.19 inch Rotors Rear
- Wilwood Brake pads low dust Front and Rear
- Wilwood Proportioning Valve.
- Wilwood Stainless steel brake lines.
Electronics
- American Autowire complete full harness
- Ring Brothers Gauge Insert
- Ring Brothers Light switches
- Dakota Digital GPS Pro Series Gauges
- New GPS Speed sensor
- AC Delco Legend Battery
- Battery wires and Terminals
- Front Oracle LED Headlights, High and low Beam
- LED Tail Lights
Suspension
-No Limit Engineering Wide Ride Chassis Pack - C10
-C-10 Wide Ride IFS includes-
-Custom bolt-in CNC formed Crossmember
-No Limit ZG spindles
-Track Tested No Limit Sway Bar
-No Limit Power Rack & Pinion
-Ridetech Complete Coilover suspension Front Suspension
-Ridetech TQ Quality Dual Adjustable 650 lbs Front Coilovers
-No Limit Engineering Upper and lower StrongArm Control arms
-Ridetech Upper and lower camber bolts
-Ridetech Upper and lower Ball joints
-Ridetech Hubs Left and Right
-No Limit Engineering Inner and outer tie rods
-Fatbar 4-Link Rear SuspensionRear 4 link system
-Ridetech TQ Quality Dual Adjustable Rear Coilovers
-Ridetech Rear Sway bar
-Ridetech Front muscle sway bar
-Ridetech Front Steering knuckle
-Ridetech Front Steering pitman Arm
-Complete Ford 9 Inch Custom Rear End
-9" MUSCLEPAK Rear End
-All components are new manufactured items (No remanufactured, refurbished or rebuilt components).
-Package includes; New Hybrid Moser 9" Housing, with OEM located mounting provisions, seamless steel tubing (3" O.D., 1/4" wall), custom alloy 31 spline bolt-in axles, bearings, studs, seals, heavy duty retainer plates, new housing ends, t-bolt kit, Trac-Loc clutch posi, "1310" Series pinion yoke, ring & pinion, set up with Timken bearings
-Auburn 3.73 gears
Wheels and Tires
HRE Forged Wheels
-Custom 22x11 Front wheels
-Custom 22x14 Rear wheels
-Chrome Center wheel caps
-Wilwood Lug nuts
-Wilwood Locking nuts
-295/30/22 Rear Nexen Roadian HP tires
-315/30/22 Yokohama Advan ST tires
21633121633221633321633421633521633621633721633821 6339216340216341216342
Parms22
07-09-2025, 03:46 PM
to the top we go!!! thank you for everyones interest. I will be more prompt to check the pm's I didn't get any notifications.
Pedigry
07-10-2025, 07:06 AM
clean!
Parms22
09-01-2025, 03:29 PM
sold!! Moderator please delete.
