View Full Version : Dodge Gen3 speed measurement on an older vehicle
Vimes
01-28-2025, 12:18 PM
The Gen3 Hemis use a wheel sensor as a speed sensor, not a sensor on the transmission output shaft like GM does. Is there an aftermarket solution for this problem? Comes to it I can probably rig something up using one of the Corvette ABS sensor rings, but if there's a ready-made solution that uses the factory Dodge ECM I'd rather go that route.
boss_hoss
01-28-2025, 03:53 PM
Without knowing too much about your set up, I'd probably starts with Dakota digital; they have a lot of different options for speed sensors. Motion raceworks also has a few wheel speed sensor options
Vimes
01-28-2025, 04:00 PM
Yeah, should have put in more detail. 2003 Dakota, C5 Corvette front/rear suspension from the cradles out, putting a 2018 Challenger 392/8HP takeout into it.
